- Tags:
- Development Tools
- Graphics
- Intel® Media SDK
- Intel® Media Server Studio
- Media Processing
- Optimization
Hi HeongHun,
You are using a very old SDK version, could you use a new SDK version to re-check?
Also it would be a lot of issues if you run it under root, we recommend to run as the normal user privilege.
About tutorial, there is a new release 0.0.4, could you use that, I don't think this would cause any difference in your case so just FYI.
Also, there is a mistake in your description about the driver, media SDK uses i915 not i965, we used to support both but we only support i915 now.
Mark
Could you tell me what is your hardware?
For our release support, we support N and N-1, where N to be the current processor version.
no, i915 is in kernel, iHD file is the UMD module to hook it up.
Mark
Thank you for your reply.
hardware is 'Intel(R) Xeon(R) CPU E3-1286 v3 @ 3.70GHz'
what is mean support N and N-1?
Does the video group user load only the iHD_drv_video.so library when set with a kernel mode driver?
Thank you..
Hi SeongHun,
From the log of your first post, the problem is the initialization of UMD which could be caused by multiple issues but we should first check the system environment. Your code was loading i965 driver which is not correct, it should load i915 KMD.
I also assumed you have installed the Media Server Studio based on our getting started guide and rebuilt the kernel which should have i915 KMD.
For platform support, the processor is Haswell, our current release support Skylake and above which means you have to use a very old Media SDK release. We don't support these release, means we don't fix the bug unless you can prove it can be reproduced in new hardware.
Mark.
