Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
video display on linux platform
johnson_j_
Hi Intel:
I want to have a video player on linux platform.
On decoding part, i will use intel media server SDK, but on display part,  which module should i  use, do you have any suggestions ?
Thx!
Surbhi_M_Intel
Hi Johnson,
I believe you are looking for a player to play the decoded output. You can use ffplay to play the bitstream and a yuv player to run any YUV's. I hope I have got your question right.
-Surbhi
johnson_j_
Does media SDK and opengl  work together ok?
Jeffrey_M_Intel1
In general, Media SDK for Linux Servers is focused on headless use cases.  Methods to display locally aren't a priority.  The samples illustrate how to display via X11, but using this path isn't recommended for most cases because when Media SDK is initialized this way an active X session is always required.  Because of this the X11 path in the samples isn't well optimized and may contain bugs -- it isn't intended to show a suggested way to implement rendering.
Media SDK works with VAAPI surfaces in Linux and there should be ways to interoperate with OpenGL.  However, since this forum is focused on helping with Media SDK we may not be able to provide much help with the display component.
johnson_j_
whare are the samples illustrate how to display via X11?
