Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
vp8/9 sample decode
MyMother
hi
OS: Ubuntu 12.04
       MediaSamples_Linux_6.0.16043175.175
       MediaServerStudioEssentials2015R6
Platform:  i5-4570S
I  got following result
[release] $ ./sample_decode_x11 vp8 -sw -i src_4Mbps.vp8 -p bffc518cde134df98a96f4cf816c0fac
Return on error: error code -3, /home/dspuser/Downloads/IntellMediaSDK/MediaSamples_Linux_6.0.16043175.175/samples/sample_common/src/sample_utils.cpp   613
Return on error: error code -3, /home/dspuser/Downloads/IntellMediaSDK/MediaSamples_Linux_6.0.16043175.175/samples/sample_decode/src/pipeline_decode.cpp        139
Return on error: error code 1,  /home/dspuser/Downloads/IntellMediaSDK/MediaSamples_Linux_6.0.16043175.175/samples/sample_decode/src/sample_decode.cpp  501
After checking the above line number, I got.
    // check header
    MSDK_CHECK_NOT_EQUAL(MFX_MAKEFOURCC('D','K','I','F'), m_hdr.dkif, MFX_ERR_UNSUPPORTED);
    MSDK_CHECK_NOT_EQUAL(MFX_MAKEFOURCC('V','P','8','0'), m_hdr.codec_FourCC, MFX_ERR_UNSUPPORTED);
Then I referred https://software.intel.com/en-us/forums/intel-media-sdk/topic/605925 and have question.
Q1. does VP8/9 have software supported ??
Q2, If yes, any user guide for enabling with sample was provided??
Surbhi_M_Intel
Hi there,
There is no VP8 and VP9 sw implementation support available through Media SDK. Since VP8 and VP9 codec are opensource, so one can really use the sw implementation there. Vp8 decode hw acceleration is available on 5th generation to use.
Surbhi
Kishor_B_
Hi Surbhi.
I followed SDK API Reference Manual for VP8 (API Version 1.12) for enabling VP8 decoder in the test application.
Codec ID is set to MFX_CODEC_VP8 and DataFlag is set to MFX_BITSTREAM_COMPLETE_FRAME. Successfully compiled.
A complete frame is read into the input buffer but DecodeHeader function returns an error, which reads
Unsupported feature/library load error. src/simple_decode_vmem.cpp 104
Any ideas, how to address overcome this error?
My usage is ./simple_decode_vmem -auto ~/Desktop/GPU/TestStreams/DV.ivf
My setup is: SDK API v 1.16, Core i7-5600U CPU @2.60GHZ, 4 cores, Broadwell (5th generation as suggested above), Turbo Disabled, HD graphics 5500, centOS 7.1
Regards, Kishor
Surbhi_M_Intel
HI Kishore,
Media SDK tutorials are not configured for VP8 codec. In Media Server Studio, VP8 decode is implemented as a plugin and sample_decode is configured with plugin model for VP8 and HEVC. Can you try sample decode to make sure VP8 decode works on your system?
cmd : ./sample_decode_drm vp8 -i ../content/test_stream_vp8.ivf -p f622394d8d87452f878c51f2fc9b4131
f622394d8d87452f878c51f2fc9b4131 - GUID plugin for VP8 codec, defined in plugins.cfg present at /opt/intel/mediasdk/plugin directory
If this works, then you can either change the tutorial to add plugin support and set the data flag or make changes in sample_decode to add the full frame and set dataflag.
Hope this helps.
Surbhi
Kishor_B_
Hi Surbhi,
Thank you for the quick reply. Sample decode gave me following errors. What could have gone wrong?
[root@CENTOSHOST MediaSamples_Linux_bins_6.0.16043175.175]# ./sample_decode_drm vp8 -i ./content/test_stream_vp8.ivf -p f622394d8d87452f878c51f2fc9b4131
plugin_loader.h :157 [INFO] Plugin was loaded from GUID
libva info: VA-API version 0.35.0
libva info: va_getDriverName() returns 0
libva info: User requested driver 'iHD'
libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so
libva info: Found init function __vaDriverInit_0_32
libva info: va_openDriver() returns 0
Return on error: error code -3,    /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK3/git/mdp_msdk-samples/samples/sample_decode/src/pipeline_decode.cpp    667
Return on error: error code -3,    /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK3/git/mdp_msdk-samples/samples/sample_decode/src/pipeline_decode.cpp    289
Return on error: error code 1,    /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK3/git/mdp_msdk-samples/samples/sample_decode/src/sample_decode.cpp    501
plugin_loader.h :183 [INFO] MFXBaseUSER_UnLoad(session=0x0x7fc79ed19230), sts=0
Regards, Kishor
Surbhi_M_Intel
Hi Kishore,
Your system definitely supports VP8 codec, plugin was successfully able to load.  Can you check if other codec like h264 works fine for you, decode a h264 stream present in the content folder to make sure Media Server Studio has been correctly installed.
Are you using Media Server Studio version 2015 R6? Are you using pre-compiled binaries?
-Surbhi
Kishor_B_
Hi Surbhi,
We have validated MPEG2/H264 decoder/encoder without any issues.
Yes, we are using MSS 2015 R6 and the precompiled binaries that came along with. We are using the Decoding Sample Version 6.0.16043175.175.
The precompiled decode binary does not seem to support vp8, even as plug-in. Here is the codec list it displays
Supported codecs (<codecid>):
   <codecid>=h264|mpeg2|vc1|mvc|jpeg - built-in Media SDK codecs
   <codecid>=h265|capture            - in-box Media SDK plugins (may require separate downloading and installation)
Am I using the right version of pre-compiled binary?
Kishor
Kishor_B_
Hi Surbhi,
Any updates on this?
Is there a document which explains sample_decode to be configured with plugin model for VP8?
Thank you.
Best Regards, Kishor
Surbhi_M_Intel
Hi Kishore,
There is a VP8 manual available online to get more details - https://software.intel.com/sites/default/files/mediasdkvp8-man.pdf. I know there is no mention of VP8 codec support in sample_decode but it does support, it is something we missed to mention. I don't think pre-compiled binaries should have an issue, but you can clean and build the binaries again. check build.pl to clean and recompile the binaries. Another thing which can be helpful is to capture tracer logs, present at installed directory. The tracer logs capture the media sdk calls which can help to debug. Can you also send the o/p of cmd "uname -r" and check the vp8 decode plugin in /opt/intel/mediasdk/plugins/plugin.cfg?
Surbhi
Kishor_B_
Hi Surbhi,
The manual is not discussing preparing plug-in based applications. A sample application demonstrating  the plug-in architecture would be beneficial, considering we have to approach our applications in similar fashion.
3.10.0-229.1.2.39163.MSSr4.el7.centos.x86_64
It is available. The content as follows.
[VP8_Decoder_f622394d8d87452f878c51f2fc9b4131]
GUID =  f622394d8d87452f878c51f2fc9b4131
PluginVersion = 1
APIVersion = 272
Path = /opt/intel/mediasdk/plugins/libmfx_vp8d_hw64.so
Type = 1
CodecID = VP8
Default = 0
Where can i find this build.pl? Is the source of the binaries, which came with SDK (sample_decode_x11) available?
Surbhi_M_Intel
Kishore,
I hope you have downloaded the samples package separately on your system, if not the please download it from here - https://software.intel.com/en-us/intel-media-server-studio-support/code-samples
After the download, go to installed directory>samples and there is a build.pl file to clean and rebuild the samples. Use drm samples, which are the preferred samples to use and send the tracer logs in case of failure.
-Surbhi
