Migrating to SYCL
One-stop forum for getting assistance migrating your existing code to SYCL
50 Discussions
DPC++ compatibility tool error, oneAPI samples, Devcloud
Eltablawy__Alaa
I'm trying to run one of the oneAPI samples for Cuda code migration on the devcloud.
The code I'm running is https://github.com/oneapi-src/oneAPI-samples/tree/master/Tools/Migration/folder-options-dpct
When I run the command in the README.md, I get the following:
Case1:
dpct --in-root=foo --out-root=result/foo foo/main.cu foo/bar/util.cu --extra-arg="-Ifoo/bar/"
dpct exited with code: -5 (Error: Path for CUDA header files is invalid or not available. Use --cuda-include-path to specify the correct path to the header files)
When I add the path to include/cude, I get the following:
Case2:
dpct --cuda-include-path=<path to cuda>/include --in-root=foo --out-root=result/foo foo/main.cu foo/bar/util.cu --extra-arg="-Ifoo/bar/"
Processing: /home/u52/workstation/CudaToDPC++/oneAPI-samples/Tools/Migration/folder-options-dpct/foo/main.cu
Skipping /home/u52/workstation/CudaToDPC++/oneAPI-samples/Tools/Migration/folder-options-dpct/foo/main.cu. Compile command not found.
Processing: /home/u52/workstation/CudaToDPC++/oneAPI-samples/Tools/Migration/folder-options-dpct/foo/bar/util.cu
Skipping /home/u52/workstation/CudaToDPC++/oneAPI-samples/Tools/Migration/folder-options-dpct/foo/bar/util.cu. Compile command not found.
dpct exited with code: 1 (Migration not necessary; no CUDA code detected)
is the DPC++ compatibility tool supported on Devcloud? and is there any documentation for using the tool on the Devcloud?
RahulV_intel
I have tried the steps (given in the tutorial) in my environment. The migration and compilation/run were successful in my case.
Could you please specify your CUDA toolkit?
DPCT requirements:
https://software.intel.com/content/www/us/en/develop/articles/intel-dpc-compatibility-tool-system-requirements.html
Rahul
Eltablawy__Alaa
Thanks, Rahul for your answer, I used the toolkit include from 10.2.
Which toolkit you used in your env. ?
Alaa
RahulV_intel
Apologies for the late response. I have the same CUDA toolkit version.
As a possible workaround, could you try changing your CUDA application to a different directory and give it a try? (CUDA toolkit installation directory and CUDA application directory should be different). Let me know if it helps.
Also, try to migrate a simple CUDA vector add code and let me know how it goes.
dpct --cuda-include-path=<path to cuda>/include vecadd.cu
Rahul
RahulV_intel
Could you please confirm if your issue is solved? Let us know if you face any issues.
Rahul
Eltablawy__Alaa
Thanks Rahul, yes, I have the issue resolved. The solution to my issue us as follow:
1- as you suggested, changing the CUDA application directory helped in resolving the following issue:
Processing: /home/.../oneAPI-samples/Tools/Migration/vector-add-dpct/src/vector_add.cu
Skipping /home/.../oneAPI-samples/Tools/Migration/vector-add-dpct/src/vector_add.cu. Compile command not found.
2- Changing the CUDA application path not to be the same as CUDA lib, helped with that issue:
So I used the following command to migrate: dpct --cuda-include-path=../include --in-root=. src/vector_add.cu --out-root=output/
Also, without specifying the --in-root option, it produced the same output.
Thanks for your help!
RahulV_intel
Since your issue is resolved, could you let me know if I can close this thread from my end?
Rahul
Eltablawy__Alaa
Sure, it's resolved, and you can close the issue.
Thanks!
Alaa
RahulV_intel
Thanks for the confirmation. Intel will no longer monitor this thread. Further discussions on this thread will be considered community only.
Rahul
