Migrating to SYCL
One-stop forum for getting assistance migrating your existing code to SYCL
48 Discussions
DPCT use in cuda header files (.cuh).
MountainLogic
What is the correct way to handle #include xxx.cuh file from a cuda kernel with the DPCT tool?
I have a single kernel.cu file that I a porting to sycl using DPCT that has a cuda include file, kernel.cuh.  I seem to be getting a correct port, except the kernal.dp.cpp file keeps the "#include kernel.cuh"
I also seem to be having a problem with device constants such as
__device__ __constant__ int d_foo;
__device__ __constant__ float d_bar;
these see to be ignored by DCPT
NoorjahanSk_Intel
 Header files which are located in same directory of source files are migratable when specified by --in-root.
 We can also use --extra-arg flag which is used to include header files explicitly.
 For more details you can refer below link:
 https://software.intel.com/content/www/us/en/develop/documentation/intel-dpcpp-compatibility-tool-user-guide/top/migrate-a-project/migrate-a-project-on-linux.html
Please try above methods during migration of header files(.cuh), if the issue still persists please provide us a sample reproducer and steps you have followed to migrate.
Thanks & Regards
Noorjahan.
NoorjahanSk_Intel
 Has the information provided helped? If not, then could you please provide the above-mentioned details.
Thanks & Regards
Noorjahan.
NoorjahanSk_Intel
I have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question
Thanks & Regards
Noorjahan.
