Migrating to SYCL
One-stop forum for getting assistance migrating your existing code to SYCL
48 Discussions
Error when using IntelSYCL in cmake and how to fix
KMEXEC
Here's how the problem occured.
My cmakelist.txt
set(CMAKE_CXX_STANDARD 20)
#dpcpp
set(CMAKE_C_COMPILER icx)
set(CMAKE_CXX_COMPILER icx)
find_package(IntelSYCL REQUIRED)
add_executable(sycl_framework_test
sycl_framework_test.cpp
add_sycl_to_target(TARGET sycl_framework_test SOURCES sycl_framework_test.cpp)
target_include_directories(sycl_framework_test PRIVATE
${SYCL_INCLUDE_DIR}
target_link_libraries(sycl_framework_test PRIVATE
${SYCL_LIBRARY}
When I cmake it, error is following
[CMake] -- SYCL_INCLUDE_DIR: E:/DevFramework/Intel/oneAPI/compiler/2025.2/include
1> [CMake] -- SYCL_LIBRARY=E:/DevFramework/Intel/oneAPI/compiler/2025.2/lib/sycl8.lib
1> [CMake] SYCL feature test compile failed!
1> [CMake] compile output is:
1> [CMake] CMake Error at E:/DevFramework/Intel/oneAPI/compiler/2025.2/lib/cmake/IntelSYCL/IntelSYCLConfig.cmake:388 (SYCL_FEATURE_TEST_EXTRACT):
1> [CMake] SYCL_FEATURE_TEST_EXTRACT Function invoked with incorrect arguments for
1> [CMake] function named: SYCL_FEATURE_TEST_EXTRACT
1> [CMake] Call Stack (most recent call first):
1> [CMake] SYCL/CMakeLists.txt:7 (find_package)
1> [CMake] -- Configuring incomplete, errors occurred!
After I checked my dpc++ files, the problem was locked on a file
Intel\oneAPI\compiler\2025.2\lib\cmake\IntelSYCL\IntelSYCLConfig.cmake
in line 388
SYCL_FEATURE_TEST_EXTRACT(${test_output})
 to fix the problem
only need to change this ${test_output} to "${test_output}"
whole cmake instruction is
SYCL_FEATURE_TEST_EXTRACT("${test_output}")
SYCL Compiler version: 20250200
