Migrating to SYCL
One-stop forum for getting assistance migrating your existing code to SYCL
50 Discussions
How to Run oneAPI Ported DPC++ Code on Nvidia GPU
-Light-
I recently ported a CUDA project to DPC++ using oneAPI and successfully ran it on an Intel GPU. Now, I would like to run the same project on an Nvidia GPU on Windows to compare performance. How can I achieve this?
I tried using the following code to target the Nvidia GPU, but it did not recognize the NVIDIA GeForce RTX 3060 on my computer.
The code is attached below.
std::vector<platform> platforms = platform::get_platforms();
for (const auto& plt : platforms) {
std::string platform_name = plt.get_info<info::platform::name>();
std::cout << "Platform: " << platform_name << std::endl;
std::vector<device> devices = plt.get_devices();
for (const auto& dev : devices) {
if (dev.is_gpu()) {
std::string device_name = dev.get_info<info::device::name>();
std::string device_vendor = dev.get_info<info::device::vendor>();
std::string driver_version = dev.get_info<info::device::driver_version>();
std::cout << " GPU Device: " << device_name << std::endl;
std::cout << " Vendor: " << device_vendor << std::endl;
std::cout << " Driver Version: " << driver_version << std::endl;
Thank you!
yzh_intel
Hi, coldplay provides CUDA plugin for dpc++ compiler, you may need to install this plugin and make sure sycl-ls can find cuda backend like below. sycl-ls is a utility provide in oneapi basekit.
$ sycl-ls
[cuda:gpu][cuda:0] NVIDIA CUDA BACKEND, NVIDIA A100 80GB PCIe 8.0 [CUDA 12.7]
During compilation you may need to add one more option to target NVIDIA gpu,
-fsycl-targets=nvptx64-nvidia-cuda
More details can be found here
