Migrating to SYCL
One-stop forum for getting assistance migrating your existing code to SYCL
48 Discussions
dpct::device_vector::resize(size_type new_size, const T &x = T()) not working properly when x != T()
fxzjshm
Hi there.
The function `resize(size_type new_size, const T &x = T())` in `dpct::device_vector` of DPC++ Compatibility Tool doesn't really fill newly allocated memory with `x` , but I think this behaviour is indicated by the function signature.
The code
void resize(size_type new_size, const T &x = T()) {
  reserve(new_size);
  _size = new_size;
(at `/opt/intel/oneapi/dpcpp-ct/2022.0.0/include/dpct/dpl_extras/vector.h`, line 227-229, version 2022.0.0)
seems not involving `x`.
For reference,  the description at cppreference.com   says
If the current size is less than count,
2) additional copies of value are appended.
And the code in NVIDIA's Thrust
template<typename T, typename Alloc>
void vector_base<T,Alloc>
 ::resize(size_type new_size, const value_type &x)
  if(new_size < size())
    iterator new_end = begin();
    thrust::advance(new_end, new_size);
    erase(new_end, end());
  } // end if
  else
    insert(end(), new_size - size(), x);
  } // end else
} // end vector_base::resize()
(at `/usr/local/cuda/include/thrust/detail/vector_base.inl`, line 329-343, CUDA version 11.3)
does what it says.
I encountered this since last summer when migrating some CUDA program to oneAPI using DPCT (I mean dpct translates `thrust::device_vector::resize()` to `dpct::device_vector::resize()` which leads to different behaviour of two versions of the program), but it seems that it hasn't changed since then.
I do not mean to offend, but may I ask, is it a bug or a feature?
ManjulaC_Intel
We are working on your issue internally and will get back to you soon.
Thanks & Regards,
Manjula
ManjulaC_Intel
We are also able to reproduce the same issue on our end.
>>I mean dpct translates `thrust::device_vector::resize()` to `dpct::device_vector::resize()` which leads to different behaviour of two versions of the program.
Can you expand more on this?
Thanks & Regards,
Manjula
fxzjshm
Hi Manjula, thanks for your reply, and sorry for the late response.
The sentence you quoted is just a senario that may trigger this inconsistence.
Consider this sample code:
#include <thrust/device_vector.h>
#include <iostream>
int main() {
    thrust::device_vector<int> d_tmp;
    d_tmp.resize(5, 233);
    for(auto x : d_tmp) {
        std::cout << x << " ";
    std::cout << std::endl;
    return 0;
Expected output is "233 233 233 233 233 ".
dpct translates this code into
#include <oneapi/dpl/execution>
#include <oneapi/dpl/algorithm>
#include <CL/sycl.hpp>
#include <dpct/dpct.hpp>
#include <dpct/dpl_utils.hpp>
#include <iostream>
int main() {
    dpct::device_vector<int> d_tmp;
        DPCT1007:0: Migration of this CUDA API is not supported by the Intel(R)
        DPC++ Compatibility Tool.
    return 0;
which gives the result "0 0 0 0 0 ".
A more detailed senario (pseudo code):
thrust::device_vector<float> d_in;
thrust::device_vector<int> d_out;
thrust::device_vector<size_t> d_param_inds;
std::vector<float> parameters;
// user inputs parameters here
for(size_t i = 0; i < parameters.size(); i++) {
    some_search_algorithm(d_in, d_out, parameters[i]);
    d_param_inds.resize(d_out.size(), i);
I have some different values of a parameter of some search algorithm inputed by user, these parameters values are stored in a std::vector .
I use d_out to store results, and d_param_inds to store the index of the parameter this search uses. (In practice the parameter may be a huge struct and expensive to copy, so just store the index here.)
In this case, the `resize()` is important, but the dpct::vector cannot work as expected, it just stores 0.
Thank you for reading this far.
ManjulaC_Intel
We are able to reproduce the same issue on our end. I am checking your issue with the concerned team, and waiting for the feedback. I will get back to you with an update.
Thanks for reporting this issue.
Thanks & Regards,
Manjula
ManjulaC_Intel
Thank you for your patience. The issue raised by you has been fixed in oneAPI 2022.2(in Compatibility tool 2022.1)​version. Please download and let us know if this resolves your issue.
Manjula
ManjulaC_Intel
I have not heard back from you. This thread will no longer be monitored by Intel.
If you need further assistance, please post a new question.
Thanks & Regards,
Manjula
fxzjshm
Sorry for the late response, confirm fixed.
Thank you!
