17244 Discussions
285k电脑无法开启200sboostboost
Viktorxxx
我进入bios后,按F7进入高级模式,仅开启了200sboost,然后,bios帮我自动开启了xmp1。然后内存频率也没有变成8000,依旧是7200.NGU和D2D依旧没变化,是默认状态,没有超频到32,这和我的bios仅开启xmp1是一样的。我的bios和微码都是最新的,为3002和0x121.请问这个是什么情况。如图是我的配置图。
Manas_Intel
Hello @Viktorxxx!
Thank you so much for sharing those details and the configuration diagram with our community. It is great to see that you are already utilizing the latest 3002 BIOS and 0x121 microcode to keep your system up to date.
I was reviewing your observations regarding the 200S Boost and the NGU/D2D interconnect behaviors. To help us better understand the technical context of what you are seeing in your BIOS, could you please clarify a few details?
  • Could you let us know the exact model of the processor you are currently using?
  • Regarding the frequency targets you mentioned: To ensure we provide the most accurate technical insight, could you share the specific intent behind seeking these higher-than-default frequencies (such as the 8000MT/s memory and 32 interconnect clocks)? Understanding if these settings are intended for specific benchmarking, specialized software needs, or general system exploration helps us categorize the behavior you're experiencing with the BIOS safety fallbacks.
Knowing these details will allow us to better look into why the system is defaulting to the 7200MT/s stable profile and help us provide the most relevant information for your specific build.
Warm regards,
Manas Sharma
Manas_Intel
Hello @Viktorxxx!
I just wanted to gently follow up on my previous message.
Whenever you have a moment, could you please share the processor model you’re using, along with a bit more context around the frequency targets you’re aiming for? This will really help us better understand the behavior you're seeing and guide you more accurately.
No rush at all, just happy to continue assisting whenever it’s convenient for you. Looking forward to your update!
Warm regards,
Manas Sharma
