Hello there,
4700mq intel processor What is the processor behind the black glass-like substance.
When this black glass breaks, does it still work processor?@
Hi Seagunner,
I cannot say if it will work or not, a broken metallization on a chip may thus cause secondary overvoltage damage also thermal runaway can cause sudden failures including melting, fire or explosions.
In case you want to get more information about damage on electronic components, I recommend you the information below:
Here you can get more information:
https://en.wikipedia.org/wiki/Failure_of_electronic_components https://en.wikipedia.org/wiki/Failure_of_electronic_components
Processor physical damage information (damage to the product due to external causes):
http://www.intel.com/content/www/us/en/support/processors/000007223.html http://www.intel.com/content/www/us/en/support/processors/000007223.html
At this point, in case you want to test it, it would be under your own risk
Hellen.
