6900k
МСоро
Добрый день, подскажите как наносить термпопасту на процессор учитывая, что там сквозная дырочка на крышке.
Можно ли наносить на процессор термопасту ?
Что будет если термопаста попадет в дырку и дальше на схему??
Hello Zerg,
Thank you for contacting Intel Communities.
You can apply the thermal paste, it won't cause any damage if it gets to the hole.
The thermal paste should be applied in the center of the processor, when you install the heatsink/fan, it will spread all over the heat spreader.
Hope this information helps.
Please don't hesitate in replying to this post if you need further assistance.
Juan Carlos
Hello Zerg,
I was reviewing this thread and I wanted to know if you need further assistance?
Please don't hesitate in replying to this post if you need additional information.
Juan Carlos
