About GPU
SPaul3
My Desktop Computer Congfigaration is:
Processor: Intel(R) Core(TM) i5-8400 CPU @ 2.80GHz (6 CPUs)
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: Z370XP SLI
BIOS: F5 (type: UEFI)
Ram: 8GB (2400 BUS)
Graphic Card: GeForce GTX 1050Ti
Hard Disk Drive: SSD 120GB for "C" drive and 1TB for others Drive
Power supply: 650WT
OS: Windows 10 Pro
My question is :
1. My Computer is not faster that I was expecting. Now what can I do?
2. I have only NVIDIA Geforce GTX 1050Ti "Display adapters" . Why I can not add "Microsoft or intel Display adapters" also ?
3. How , I can use "Intel UHD display and NVIDIA Geoforce adaoters"
Thank you so much.
AlHill
1. Faster than what?
2. and 3. Your motherboard/bios will likely disable the onboard graphics (Intel) if you insert an add-on card (nvidia). There is also the possibility that there is a bios setting that may allow both to operate concurrently. To verify, check your bios. If there is no such setting to allow both onboard and add-on to operate concurrently, then you have to choose which one you want. Personally, I would stay with the nvidia. However, if you want to use the onboard graphics, just remove the nvidia card.
Doc
SPaul3
1. My computer is not faster. Working slow.
2. Can you please tell , How to check BIOS setting or change this ?
Thank you so much.
Sanjoy
AlHill
1. You will have to provide a lot more information about "slow"
2. It is gigabyte's board and bios. You need to ask them.
Doc
SPaul3
1. Need so much time to open my Desktop . Also , when I am using "Photoshop/indesign 2018" , My desktop take too much time to open that type of software. need to complete 3/4 minutes to complete "Restart" (When I am pressing ) .
2. Thank you. Understand this
Thank you so much.
Sanjoy
AlHill
Performance can be affected by many things - memory, startup programs, viruses, anti-virus programs, etc.
What anti-virus program are you running?
Doc
SPaul3
I am using " Windows10 Defender" . I do not have any other antivirus.
AlHill
download, run, and attach the results of this utility: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Download Intel® System Support Utility for Windows*
Then, one of the intel support engineers will be able to assist you.
Doc
SPaul3
