17278 Discussions
Alder Lake S Platform Intel® IO Margin Too
Ken_Long
Hi all,
I would like to download the Alder Lake-S Platform Intel® IO Margin Tool to perform some SSD design compatibility testing.
I found that related tools had been released before, but currently I can only find the Alder Lake-PS or Alder Lake-N platform versions.
The download link for the Alder Lake-S platform tool appears to be no longer available.
I would like to seek some help and would appreciate any suggestions or advice you may have.
VonM_Intel
Hi Ken_Long,
Thank you for posting in our Community. I understand that you are looking for the Alder Lake-S Platform Intel® IO Margin Tool to support your SSD design and compatibility testing, and that the previously available download link is currently no longer accessible.
To better assist you and ensure I point you in the right direction, could you kindly help clarify a few details:
  • Which exact Alder Lake-S processor or platform configuration are you working with?
  • Is your testing focused on SATA, NVMe, or a specific PCIe generation SSD design?
  • Are you currently working within an internal validation environment or an external lab setup?
  • Do you require a standalone tool, or would an alternative Intel validation suite or documentation also work for your use case?
Once I have a bit more context, I can help guide you toward the most appropriate available resources or alternatives that may support your testing requirements.
Have a nice day!
Von M.
Ken_Long
Dear Von,
Thank you for your prompt response.
Due to the need to perform some SATA SSD design compatibility testing on an i5-12400 + B760M platform, I would like to download the Alder Lake-S Platform Intel® IO Margin Tool.
I found that this tool had been released previously, but currently I can only find the Alder Lake-PS or Alder Lake-N platform versions, while the download link for the Alder Lake-S platform version appears to be unavailable.
Could the administrator please restore the download link for this Tool?
ADL S Intel IO Margin Tool (IOMT) forWindows PV release Rev 1.0.22
*The above link is no longer available.
https://www.intel.com/content/www/us/en/secure/design/confidential/software-kits/kit-details.html?kitId=637467
VonM_Intel
Hello Ken_Long,
I’ll need to conduct additional research on this issue and will post an update in this thread once I have more information about this matter.
Have a nice day!
Von M.
VonM_Intel
Hello Ken_Long,
Thank you for your patience and for sharing the link with us.
After carefully reviewing the provided link, we’ve found that the document is currently no longer accessible as it appears to have been unpublished. Because of this, we will need to have it further validated by our internal RDC support team to ensure we can properly investigate and restore access if needed.
To move this forward smoothly, we have created a new support ticket for your concern since the original request originated from the community channel. This will help ensure your case is properly tracked and handled through the correct support path.
Please be assured that the new ticket has been routed to our RDC team for further review, and they will continue the investigation using the reference from this case number. You will be contacted directly via email once there are updates or if additional details are required from your side.
We appreciate your understanding while we coordinate this internally, and we’ll make sure to keep you informed as soon as we receive any progress from the team.
Have a nice day!
Von M.
