When Ubuntu 25.04 is installed, 3 sycl devices show up, which are the Intel ARC GPU, CPU, and the other device which I think is the NPU. Using the Intel oneAPI toolkit to run sycl-ls shows all of the devices under Ubuntu.
But if I install Fedora 42, then the only sycl device that shows up, is the CPU. I know its a device issue, but is there a way to get the other sycl devices to show up for other kernels and distros? I know I have installed intel oneAPI toolkit correctly. But what Intel drivers are used, or needed for all of the sycl devices to show up?
I would really appreciate any help on this problem.
Hello Sgodsell,
To help you effectively with your concern, please share the information below.
1. What is the exact model of the Asus NUC you are using?
2. What version of Fedora 42 are you running,
3. What is the current version of the Linux kernel you are using?
4. Are there any error messages or logs that provide more information about the issue?
5. Have you attempted any troubleshooting steps so far? If so, what were they and what were the results?
Best regards
Jed G.
Hello Sgodsell,
Jed G.
Hello Sgodsell,
Jed G.
