17279 Discussions
Atom N2600 and Memory Timings
KHans13
Hi all,
A few months ago, I bought a 2 GB stick of G.Skill RAM to put in my Gateway LT4004u netbook. It's rated at DDR3/1600 CL9. As I understand it, my Atom N2600 underclocks the RAM to 800 MHz. I was hoping to get CL5 at that speed out of the RAM, but when I started up CPU-Z 1.64 to check, all of the fields were blank. The program can read the SPD of the stick just fine, but it doesn't report any values in the Memory tab (other than its size). Is there any way to see what timings my RAM is running, and even better, change them if needed?
Thanks in advance!
KHans13
I tried running HWInfo32, and it reports that my RAM is running at 5-5-5-14 timings. Huzzah!
FGonz6
New Contributor III
Normally that option can be found and edited in the BIOS under configuration>memory overrides tab, but due to the fact that your system is an original equipment manufacturer (OEM) you may want to contact Gateway* so they can confirm if this option can be seen in your BIOS.
You may want to contact them at 800-846-2301
KHans13
Tried calling, got told my product is not eligible for tech support. I bought it refurbished, maybe that's why.
Now what? I've tried using other tools like CPU Tweaker and SPD Reader, both of which failed.
KHans13
