BIOS locked!!!
VGall1
I have a TV box whit Intel atom z3735f
Model name: Wintel Mini iPC002 (Vensmile W10) Producer: Vissontech [search it :D]
Initially i have a problem whit the two USB and i think that it was disable on the bios setup. I procure an otg cable and connect the keyboard in a micro-usb port to finish a pre-configuration of Windows. Then i reboot and enter in the bios setup. Whit my big surprise, everithing is enable!..then reboot and try the two USB, but nothing: don't work!
At last, i re-enter in the bios setup and i can't select or change nothing!..I repeat the operation but i can't change nothing in the bios setup and the two USB don't work!!
Do you say me one way to reset the bios?..or one solution for the problem that i described in this post?
Exist a tool to flash a bios in WinOS for this product whit Intel processor?
Thank you for your time!
Hope in more reply
Best regardes
Soon. Svinsz
Kevin_M_Intel
Hello Svinsz,
Please note that we provide internal components to system manufactures and they will design their own systems with special features.
I regret to say that from our side, we do not have information about the correct configuration for this device so I recommend you contacting the device manufacture for them to help you with this.
Here is their website:
http://www.vissontech.com/download.html http://www.vissontech.com/download.html
Kevin m
VGall1
Thank you for your reply and excuse me for off-topic discussion!!
i just visit every page in the web!! thanks anyway!!
Bye
Svinsz
