16968 Discussions
BSOD from Turbo Boost Max
CMees
I've been getting the occasional BSOD recently: IRQL_NOT_LESS_OR_EQUAL
Using WhoCrashed by Resplendence has suggested it may have something to do with the Intel(R) Turbo Boost Max Technology 3.0 Driver
I have disabled the service from starting for now, to see if that fixes it, but I'm wondering if anyone else have any experience with this, or can give insight into what may be going on?
Operating System Windows 10 Pro 1703 15063.296
Processor (CPU) Intel® Core™i7 Six Core Processor i7-6850K (3.6GHz) 15MB Cache
Motherboard ASUS® X99-E: ATX, Broadwell-E CPU, USB 3.0, SATA 6 GB/s
Memory (RAM) 32GB Corsair Vengeance DDR4 3000 MHz X.M.P (4 x 8GB)
Intel - Turbo Boost Max Technology 3.0 version 1.0.2.1
Intel - Turbo Boost Max Technology 3.0 Service version 1.0.0.1031
This is what WhoCrashed said for the last crash:
On Fri 12/05/2017 03:51:04 your computer crashed
crash dump file: C:\Windows\Minidump\051217-17406-01.dmp
This was probably caused by the following module: http://www.google.com/search?q=ntoskrnl.exe ntoskrnl.exe (nt+0x16C310)
Bugcheck code: 0xA (0xFFFFD401003160C0, 0x2, 0x1, 0xFFFFF801847D7E7E)
Error: http://www.google.com/search?q=MSDN+bugcheck+IRQL_NOT_LESS_OR_EQUAL IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\ntoskrnl.exe
product: http://www.google.com/search?q=Microsoft%C2%AE%20Windows%C2%AE%20Operating%20System Microsoft® Windows® Operating System
company: http://www.google.com/search?q=Microsoft%20Corporation Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: http://www.google.com/search?q=intelnit.sys intelnit.sys (IntelNit+0x660A)
file path: C:\Windows\system32\drivers\intelnit.sys
product: http://www.google.com/search?q=Intel(R)%20Turbo%20Boost%20Max%20Technology%203.0%20Driver Intel(R) Turbo Boost Max Technology 3.0 Driver
company: http://www.google.com/search?q=Intel%20Corporation Intel Corporation
description: Intel(R) Turbo Boost Max Technology 3.0 Driver
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: intelnit.sys (Intel(R) Turbo Boost Max Technology 3.0 Driver, Intel Corporation).
Google query: http://www.google.com/search?q=intelnit.sys+Intel%20Corporation+IRQL_NOT_LESS_OR_EQUAL Intel Corporation IRQL_NOT_LESS_OR_EQUAL
The minidump can be downloaded here: https://www.dropbox.com/s/hnsymjz9i7gkk0p/051217-17406-01.dmp?dl=0 Dropbox - 051217-17406-01.dmp
The full memory dump:https://www.dropbox.com/s/sk2fqxr3x146eaw/MEMORY.DMP?dl=0 Dropbox - MEMORY.DMP
Thanks for any help anyone can give!
In this case, you will need to attach it to the post; no personal information is collected. Intel is committed to protecting your privacy. See http://www.intel.com/privacy Intel's Privacy Notice.
Ivan U.
PHida
I tried submitting a ticket with no avail, same issue I've got. freeze on Turbo boost
JKrie
How do i attach the systeminfo.txt file? Or should i just paste it in?
You can attach it, please see how at the pictures below:
Click reply and see the red arrow from the pictures.
Ivan U.
JKrie
File attached
Thank you!
Ivan U.
Hello all,
Just one question, if you have the TB 3.0 enabled in the bios, is this failing on Safe Mode?
If the TB 3.0 is enabled and you disable Hyper Threading the issue persists.
Ivan U
JKrie
I haven't tried either of these, and unfortunately with TB 3.0 enabled it happens once or twice a week. I can't really work for a week either in safe-mode or with hyperthreading disabled.
FWIW, I haven't had any BSOD since disabling TB 3.0 in the BIOS. However, the machine performance seems lower.
Thank you for that information.
Ivan U.
Hello Claire_Monkey,
I sent you a private message about a warranty request.
Ivan U.
JKrie
IntelCorporation Ivan any update on this? We have another person in the office also experiencing this BSOD now. All evidence we're seeing points to the driver. I will (privately) share my MEMORY.DMP file if it will help your engineers find the problem.
I am having the exact same problems as stated in this thread. I have a new i7-7820x, with an ASUS Prime-x299-A Motherboard. Any help would be appreciated.
Here is what I got from WhoCrashed:
On Sun 9/17/2017 2:26:04 PM your computer crashed
crash dump file: C:\Windows\Minidump\091717-8671-01.dmp
This was probably caused by the following module: http://www.google.com/search?q=intelnit.sys intelnit.sys (IntelNit+0x5325)
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFF8004A895325, 0xFFFF9C00C02CEEB8, 0xFFFF9C00C02CE700)
Error: http://www.google.com/search?q=MSDN+bugcheck+SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M
Bug check description: This indicates that a system thread generated an exception which the error handler did not catch.
I had updated to driver 1.0.0.1033 and did have the latest driver. I went back to driver 1.0.0.1032 to see if it does better because my problem started with driver 1033, which is the latest.
Any suggestions how I can prevent more BSOD ?
Thanks for any help.
CMees
The only way to prevent the BSOD is to go in to BIOS and turn off the Turbo Boost feature from ever running.
Intel have admitted to me there is a fault with my processor and if I had bought it less than a year ago they would've replaced it free of charge. As it happens they took 3 months to tell me this, and therefore I'm apparently not entitled to one.
Raise a support ticket directly with them, and they should offer you a replacement.
As far as anyone has told me, there is no way of fixing Turbo Boost with software.
BWint6
So is this actually a fault with the processor itself and not the software?
CMees
That's what they told me. They certainly haven't released a software fix of any kind.
Thanks for the information. I started having problems once I upgraded the driver to 1.0.0.1033. I went back to 1032 and hope this helps. I would hate to disable Turbo Max.
BWint6
Oh right.
I don't think they will either.
I have managed to resolve the issue by just setting it to 'disabled' but still keeping the software installed.
It reinstalls itself automatically on restart if you uninstall it from the PC
It is rather annoying that I can't benefit from the boosted processor, but I would rather have stable performance and not a BSOD every few hours.
CMees
Yeah I couldn't get it to actually disable anywhere other than in BIOS. Windows likes to automatically have it on.
It's been fine since it was disabled. I'd rather have it on of course, but I tried everything, my choice was turn it off or constant BSOD.
And then Intel confirmed that I'd be entitled to a replacement if I was in warranty as it was a hardware fault.
Obviously you might not have the same problem as me, but this is my experience.
BWint6
Thanks claire_monkey. I know what you mean about the constant BSOD - so frustrating.
I will speak to Intel regarding a replacement as I think mine is still in Warranty
BWint6
Ivan, the only solution I found was to set Turbo Boost to 'disabled'
Now I haven't had any other BSOD's
Until Intel sort out their phony turbo boost driver it is the only way to stop it crashing the entire system.
It is a shame that I can't get the performance benefits of turbo boost, but I am not sure what else to do at this stage and I am sick of it crashing my pc when i'm in the middle of working or worse on the phone with a client!
CVigu
Hi guys,
Let me start by saying i feel all of your pain.
I've been getting BSOD's daily since i built my new X299 system.
initially thought it was the memory, so at the point where i'm about the RMA the memory. But then i came across this post.
Learnt how to analyze my crashes, and seemingly (the recent ones anyway) IRQL_NOT_LESS_OR_EQUAL are pointing to intelNit.sys.
So what do i need to do here? I get at least 4 BSOD's a day, driving me crazy.
here's my WhoCrashed analysis of the last 5:
Computer name: CASEYV-PC
Windows version: Windows 10 , 10.0, build: 15063
Windows dir: C:\Windows
Hardware: ASRock, X299 Taichi
CPU: GenuineIntel Intel(R) Core(TM) i9-7900X CPU @ 3.30GHz Intel586, level: 6
20 logical processors, active mask: 1048575
RAM: 16867180544 bytes total
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Tue 9/26/2017 2:16:50 PM your computer crashed
crash dump file: C:\Windows\Minidump\092617-10296-01.dmp
This was probably caused by the following module: http://www.google.com/search?q=ntoskrnl.exe ntoskrnl.exe (nt+0x16C580)
Bugcheck code: 0xA (0xFFFFA6025D85F0C0, 0x2, 0x1, 0xFFFFF803949DD87A)
This was probably caused by the following module: http://www.google.com/search?q=intelnit.sys intelnit.sys (IntelNit+0x6612)
On Mon 9/25/2017 10:27:37 AM your computer crashed
crash dump file: C:\Windows\Minidump\092517-10125-01.dmp
Bugcheck code: 0xA (0xFFFF868AF9B71800, 0x2, 0x1, 0xFFFFF8016F5D087A)
Bug check description: This indicates that Micr...
