17248 Discussions
BSOD with eGPU on Lunar Lake
rcyyz
I am on a ThinkPad X1 Carbon 13th gen. I have an eGPU (Radeon 6700XT) connected via an enclosure and Thunderbolt 4 (Intel certified cable). When booting with the eGPU connected, it runs for a while before BSODing, especially when handling intensive graphics workloads like games.
After an investigation of the event viewer, it seems that a WHEA_UNCORRECTABLE_ERROR causes the BSOD, which is preceded by a flurry of WHEA code 17, indicating corrected errors, all stemming from the eGPU.
A Reddit search indicated that running bcdedit /set {current} pciexpress forcedisable as administrator fixes the issue, and it worked for me, but this disables the integrated Intel GPU, so it's a shoddy workaround at best.
The eGPU works fine on my old laptop. These people seem to have had similar issues to mine on the same architecture, which is why I suspect this may be an Intel problem:
Lunar lake PCIE Crash while connecting EGPU - Intel Community
A fix for WHEA log 17 errors! : eGPU
I am available to provide any dump files, event logs etc on request.
I can also confirm that I've installed all relevant driver/OS updates from Microsoft, Intel, Lenovo, AMD, etc.
JedG_Intel
Hello rcyyz,
To address your concern properly, please share the information below.
1. Have you contacted Lenovo to see if your current set up is supported?
2. Do the system work when the eGPU is not connected?
3. Kindly share the Event Logs.
Additionally, to have a better understanding of your system configuration and components please generate System Support Utility (SSU) report. Please follow instructions here and send the report - How to get the Intel® System Support Utility Logs on Windows*
Best regards
Jed G.
JedG_Intel
Hello rcyyz,
Jed G.
rcyyz
Hey Jed:
Apologies, I just moved to a new residence. I've been pretty busy and haven't had a chance to unpack my setup yet, I will provide you with event logs, etc. when I have the chance.
I can confirm that the system works without the eGPU connected, and while Lenovo isn't in the business of certifying individual eGPU enclosures, the general use case of eGPUs is supported.
JedG_Intel
Hello rcyyz,
Thank you for the update. We would appreciate it if you could share the reports at your earliest convenience, as this will enable us to proceed with a thorough investigation.
Best regards
Jed G.
JedG_Intel
Hi rcyyz,
I'm checking to see if there are any updates on the reports? Kindly provide it at your earliest convenience so we can investigate the matter.
Jed G.
PatrickV_Intel
Hi rcyyz,
As we have not received a response from you, we will now proceed to close this inquiry. Please note that this thread will no longer be monitored.
If you still require assistance or have any further questions, we kindly ask that you submit a new inquiry through our support channels or community forum, and we will be happy to assist you.
Thank you for contacting Intel Customer Support, and we appreciate your understanding.
Patrick V.
