17377 Discussions
Blue screen for process Intel Connectivity Network Service
abruno
This happens on boot up on a HP laptop.
Updating Media
9: kd> !analyze -v
Loading Kernel Symbols
Loading User Symbols
PEB is paged out (Peb.Ldr = 000000b2`ceaf1018).  Type ".hh dbgerr001" for details
Loading unloaded module list
*                        Bugcheck Analysis                                    *
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common BugCheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff807f93a32a0, The address that the exception occurred at
Arg3: ffff98019b6ef2a8, Parameter 0 of the exception
Arg4: ffff98019b6eeab0, Parameter 1 of the exception
Debugging Details:
KEY_VALUES_STRING: 1
    Key  : AV.Page.Physical
    Value: 0x5113c0000
    Key  : AV.Page.Virtual
    Value: 0xffff98019b6e0000
    Key  : AV.Type
    Value: Unknown
    Key  : Analysis.CPU.mSec
    Value: 1765
    Key  : Analysis.Elapsed.mSec
    Value: 1785
    Key  : Analysis.IO.Other.Mb
    Value: 19
    Key  : Analysis.IO.Read.Mb
    Value: 11
    Key  : Analysis.IO.Write.Mb
    Value: 23
    Key  : Analysis.Init.CPU.mSec
    Value: 1359
    Key  : Analysis.Init.Elapsed.mSec
    Value: 9962
    Key  : Analysis.Memory.CommitPeak.Mb
    Value: 133
    Key  : Analysis.Version.DbgEng
    Value: 10.0.29547.1002
    Key  : Analysis.Version.Description
    Value: 10.2602.27.2 amd64fre
    Key  : Analysis.Version.Ext
    Value: 1.2602.27.2
    Key  : Bugcheck.Code.KiBugCheckData
    Value: 0x1e
    Key  : Bugcheck.Code.LegacyAPI
    Value: 0x1e
    Key  : Bugcheck.Code.TargetModel
    Value: 0x1e
    Key  : Dump.Attributes.AsUlong
    Value: 0x21800
    Key  : Dump.Attributes.DiagDataWrittenToHeader
    Value: 1
    Key  : Dump.Attributes.ErrorCode
    Value: 0x0
    Key  : Dump.Attributes.LastLine
    Value: Dump completed successfully.
    Key  : Dump.Attributes.ProgressPercentage
    Value: 100
    Key  : Failure.Bucket
    Value: AV_nt!ExpPoolTrackerChargeEntry
    Key  : Failure.Exception.IP.Address
    Value: 0xfffff807f93a32a0
    Key  : Failure.Exception.IP.Module
    Value: nt
    Key  : Failure.Exception.IP.Offset
    Value: 0x3a32a0
    Key  : Failure.Hash
    Value: {6f13343d-8edf-14f9-0269-6df067c74f57}
    Key  : Faulting.IP.Type
    Value: Paged
    Key  : Hypervisor.Enlightenments.ValueHex
    Value: 0x7417df84
    Key  : Hypervisor.Flags.AnyHypervisorPresent
    Value: 1
    Key  : Hypervisor.Flags.ApicEnlightened
    Value: 0
    Key  : Hypervisor.Flags.ApicVirtualizationAvailable
    Value: 1
    Key  : Hypervisor.Flags.AsyncMemoryHint
    Value: 0
    Key  : Hypervisor.Flags.CoreSchedulerRequested
    Value: 0
    Key  : Hypervisor.Flags.CpuManager
    Value: 1
    Key  : Hypervisor.Flags.DeprecateAutoEoi
    Value: 1
    Key  : Hypervisor.Flags.DynamicCpuDisabled
    Value: 1
    Key  : Hypervisor.Flags.Epf
    Value: 0
    Key  : Hypervisor.Flags.ExtendedProcessorMasks
    Value: 1
    Key  : Hypervisor.Flags.HardwareMbecAvailable
    Value: 1
    Key  : Hypervisor.Flags.MaxBankNumber
    Value: 0
    Key  : Hypervisor.Flags.MemoryZeroingControl
    Value: 1
    Key  : Hypervisor.Flags.NoExtendedRangeFlush
    Value: 0
    Key  : Hypervisor.Flags.NoNonArchCoreSharing
    Value: 1
    Key  : Hypervisor.Flags.Phase0InitDone
    Value: 1
    Key  : Hypervisor.Flags.PowerSchedulerQos
    Value: 0
    Key  : Hypervisor.Flags.RootScheduler
    Value: 0
    Key  : Hypervisor.Flags.SynicAvailable
    Value: 1
    Key  : Hypervisor.Flags.UseQpcBias
    Value: 0
    Key  : Hypervisor.Flags.Value
    Value: 55447806
    Key  : Hypervisor.Flags.ValueHex
    Value: 0x34e10fe
    Key  : Hypervisor.Flags.VpAssistPage
    Value: 1
    Key  : Hypervisor.Flags.VsmAvailable
    Value: 1
    Key  : Hypervisor.RootFlags.AccessStats
    Value: 1
    Key  : Hypervisor.RootFlags.CrashdumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.CreateVirtualProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.DisableHyperthreading
    Value: 0
    Key  : Hypervisor.RootFlags.HostTimelineSync
    Value: 1
    Key  : Hypervisor.RootFlags.HypervisorDebuggingEnabled
    Value: 0
    Key  : Hypervisor.RootFlags.IsHyperV
    Value: 1
    Key  : Hypervisor.RootFlags.LivedumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.MapDeviceInterrupt
    Value: 1
    Key  : Hypervisor.RootFlags.MceEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.Nested
    Value: 0
    Key  : Hypervisor.RootFlags.StartLogicalProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.Value
    Value: 1015
    Key  : Hypervisor.RootFlags.ValueHex
    Value: 0x3f7
    Key  : SecureKernel.HalpHvciEnabled
    Value: 1
    Key  : WER.OS.Branch
    Value: ge_release
    Key  : WER.OS.Version
    Value: 10.0.26100.1
    Key  : WER.System.BIOSRevision
    Value: 5.3.0.0
BUGCHECK_CODE:  1e
BUGCHECK_P1: ffffffffc0000005
BUGCHECK_P2: fffff807f93a32a0
BUGCHECK_P3: ffff98019b6ef2a8
BUGCHECK_P4: ffff98019b6eeab0
FILE_IN_CAB:  MEMORY.DMP
TAG_NOT_DEFINED_202b:  *** Unknown TAG in analysis list 202b
DUMP_FILE_ATTRIBUTES: 0x21800
FAULTING_THREAD:  ffffd285b1093080
EXCEPTION_PARAMETER1:  ffff98019b6ef2a8
EXCEPTION_PARAMETER2:  ffff98019b6eeab0
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1 (!blackboxwinlogon) (!blackboxwinlogonnotify)
PROCESS_NAME:  IntelConnectivityNetworkService.exe
IP_IN_PAGED_CODE:
nt!ExpPoolTrackerChargeEntry+40
fffff807`f93a32a0 f04b0fc12c06    lock xadd qword ptr [r14+r8],rbp
STACK_TEXT:
ffff9801`9b6ee1f8 fffff807`f95ad9ff     : 00000000`0000001e ffffffff`c0000005 fffff807`f93a32a0 ffff9801`9b6ef2a8 : nt!KeBugCheckEx
ffff9801`9b6ee200 fffff807`f96c9a66     : ffff9801`9b6eeab0 fffff807`f942b0e8 ffff9801`9b6ee880 fffff807`f92adb94 : nt!KiFatalFilter+0x1f
ffff9801`9b6ee240 fffff807`f94f809c     : ffff9801`00000002 ffff9801`9b6ef2a8 ffff9801`9b6e9000 ffff9801`9b6f0000 : nt!KeExpandKernelStackAndCalloutInternal$filt$0+0x16
ffff9801`9b6ee280 fffff807`f96b2a6f     : ffff9801`9b6ef2a8 ffff9801`9b6ee880 00000000`00000000 00000000`00000000 : nt!_C_specific_handler+0x9c
ffff9801`9b6ee2f0 fffff807`f92ac7b2     : ffff9801`9b6ee380 fffff807`f9000000 fffff807`f92adb94 fffff807`f90e67f4 : nt!RtlpExecuteHandlerForException+0xf
ffff9801`9b6ee320 fffff807`f93deecf     : ffff9801`9b6eeab0 ffff9801`9b6eefb0 ffff9801`9b6eeab0 ffff9801`9b6ef170 : nt!RtlDispatchException+0x2d2
ffff9801`9b6eea80 fffff807`f96bd545     : ffff9801`9b6ef1b0 ffff9801`9b6ef206 00000000`00000001 ffff8709`c8a79030 : nt!KiDispatchException+0x35f
ffff9801`9b6ef170 fffff807`f96b8225     : 00000000`00000030 fffff807`f9b73850 ffff9801`9b6ef510 00000000`00000000 : nt!KiExceptionDispatch+0x145
ffff9801`9b6ef350 fffff807`f93a32a0     : ffff9801`9b6ef7f0 ffffd285`74100000 00000000`00000000 00000000`000001d0 : nt!KiGeneralProtectionFault+0x365
ffff9801`9b6ef4e0 fffff807`f92090d3     : 00000000`00000040 ffffd285`c342a070 ffffbc00`7d81bd50 00000009`00030001 : nt!ExpPoolTrackerChargeEntry+0x40
ffff9801`9b6ef530 fffff807`f9207cc2     : 00000000`00000000 00000000`00000591 00000000`34364d43 00000000`00000000 : nt!ExAllocateHeapPool+0x13a3
ffff9801`9b6ef690 fffff807`f9b7317a     : 00000000`00000040 ffff9801`9b6efa10 00000000`00020019 fffff807`f9846f6e : nt!ExpAllocatePoolWithTagFromNode+0x52
ffff9801`9b6ef6d0 fffff807`f93d902d     : 00000000`00000000 fffff807`f9845c4b 00000000`00000000 000000b2`d0ffcc18 : nt!ExAllocatePool2+0x8a
ffff9801`9b6ef730 fffff807`f96f30b7     : ffff9801`00000016 ffff8709`c74bf790 ffff9801`9b6ef7c8 00000000`00000000 : nt!CmpAllocatePool+0x9
ffff9801`9b6ef760 fffff807`f99e8872     : ffffd285`00000007 000000b2`d0ffcc28 ffff870a`00000000 ffff8709`c74bf790 : nt!CmpAllocateParseContext+0x1b
ffff9801`9b6ef790 fffff807`f96f308d     : 00000000`00000000 00000000`00000000 00000000`00020019 ffff9801`00000000 : nt!CmOpenKey+0x1d2
ffff9801`9b6ef8b0 fffff807`f92adb94     : 00000000`00000000 fffff807`f96f3060 00000000`00000000 00000000`00000000 : nt!CmOpenKeyCallout+0x2d
ffff9801`9b6ef8f0 fffff807`f92abde5     : fffff807`f96f3060 ffff9801`9b6ef9d8 000000b2`d0ffcd08 000000b2`d0ffcfb8 : nt!KeExpandKernelStackAndCalloutInternal+0xd4
ffff9801`9b6ef960 fffff807`f9a43820     : 000000b2`d0ffcc78 fffff807`f96bcb26 00000000`00000000 00000000`00000000 : nt!KeExpandKernelStackAndCallout+0x15
ffff9801`9b6ef9a0 fffff807`f96bca55     : ffffd285`b1093080 00000000`00000002 ffffd285`b1093080 00000000`00000000 : nt!NtOpenKeyEx+0x80
ffff9801`9b6efa20 00007ffd`856e25c4     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x25
000000b2`d0ffcc08 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffd`856e25c4
SYMBOL_NAME:  nt!ExpPoolTrackerChargeEntry+40
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
STACK_COMMAND: .process /r /p 0xffffd285b060d080; .thread /r /p 0xffffd285b1093080 ; kb
BUCKET_ID_FUNC_OFFSET:  40
FAILURE_BUCKET_ID:  AV_nt!ExpPoolTrackerChargeEntry
OS_VERSION:  10.0.26100.1
BUILDLAB_STR:  ge_release
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {6f13343d-8edf-14f9-0269-6df067c74f57}
Followup:     MachineOwner
TimLawless
This appears to be related to an issue under investigation on Microsoft's forums: https://learn.microsoft.com/en-us/answers/questions/5921413/recurring-0x1e-bugcheck-in-nt-exppooltrackercharge
It appears it is a crash being caused by faulty 275HX processors when they hit that particular instruction under some unknown precondition.
