This happens on boot up on a HP laptop.
9: kd> !analyze -v
Loading Kernel Symbols
Loading User Symbols
PEB is paged out (Peb.Ldr = 000000b2`ceaf1018). Type ".hh dbgerr001" for details
Loading unloaded module list
* Bugcheck Analysis *
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common BugCheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff807f93a32a0, The address that the exception occurred at
Arg3: ffff98019b6ef2a8, Parameter 0 of the exception
Arg4: ffff98019b6eeab0, Parameter 1 of the exception
Debugging Details:
KEY_VALUES_STRING: 1 Key : AV.Page.Physical Value: 0x5113c0000 Key : AV.Page.Virtual Value: 0xffff98019b6e0000 Key : AV.Type Value: Unknown Key : Analysis.CPU.mSec Value: 1765 Key : Analysis.Elapsed.mSec Value: 1785 Key : Analysis.IO.Other.Mb Value: 19 Key : Analysis.IO.Read.Mb Value: 11 Key : Analysis.IO.Write.Mb Value: 23 Key : Analysis.Init.CPU.mSec Value: 1359 Key : Analysis.Init.Elapsed.mSec Value: 9962 Key : Analysis.Memory.CommitPeak.Mb Value: 133 Key : Analysis.Version.DbgEng Value: 10.0.29547.1002 Key : Analysis.Version.Description Value: 10.2602.27.2 amd64fre Key : Analysis.Version.Ext Value: 1.2602.27.2 Key : Bugcheck.Code.KiBugCheckData Value: 0x1e Key : Bugcheck.Code.LegacyAPI Value: 0x1e Key : Bugcheck.Code.TargetModel Value: 0x1e Key : Dump.Attributes.AsUlong Value: 0x21800 Key : Dump.Attributes.DiagDataWrittenToHeader Value: 1 Key : Dump.Attributes.ErrorCode Value: 0x0 Key : Dump.Attributes.LastLine Value: Dump completed successfully. Key : Dump.Attributes.ProgressPercentage Value: 100 Key : Failure.Bucket Value: AV_nt!ExpPoolTrackerChargeEntry Key : Failure.Exception.IP.Address Value: 0xfffff807f93a32a0 Key : Failure.Exception.IP.Module Value: nt Key : Failure.Exception.IP.Offset Value: 0x3a32a0 Key : Failure.Hash Value: {6f13343d-8edf-14f9-0269-6df067c74f57} Key : Faulting.IP.Type Value: Paged Key : Hypervisor.Enlightenments.ValueHex Value: 0x7417df84 Key : Hypervisor.Flags.AnyHypervisorPresent Value: 1 Key : Hypervisor.Flags.ApicEnlightened Value: 0 Key : Hypervisor.Flags.ApicVirtualizationAvailable Value: 1 Key : Hypervisor.Flags.AsyncMemoryHint Value: 0 Key : Hypervisor.Flags.CoreSchedulerRequested Value: 0 Key : Hypervisor.Flags.CpuManager Value: 1 Key : Hypervisor.Flags.DeprecateAutoEoi Value: 1 Key : Hypervisor.Flags.DynamicCpuDisabled Value: 1 Key : Hypervisor.Flags.Epf Value: 0 Key : Hypervisor.Flags.ExtendedProcessorMasks Value: 1 Key : Hypervisor.Flags.HardwareMbecAvailable Value: 1 Key : Hypervisor.Flags.MaxBankNumber Value: 0 Key : Hypervisor.Flags.MemoryZeroingControl Value: 1 Key : Hypervisor.Flags.NoExtendedRangeFlush Value: 0 Key : Hypervisor.Flags.NoNonArchCoreSharing Value: 1 Key : Hypervisor.Flags.Phase0InitDone Value: 1 Key : Hypervisor.Flags.PowerSchedulerQos Value: 0 Key : Hypervisor.Flags.RootScheduler Value: 0 Key : Hypervisor.Flags.SynicAvailable Value: 1 Key : Hypervisor.Flags.UseQpcBias Value: 0 Key : Hypervisor.Flags.Value Value: 55447806 Key : Hypervisor.Flags.ValueHex Value: 0x34e10fe Key : Hypervisor.Flags.VpAssistPage Value: 1 Key : Hypervisor.Flags.VsmAvailable Value: 1 Key : Hypervisor.RootFlags.AccessStats Value: 1 Key : Hypervisor.RootFlags.CrashdumpEnlightened Value: 1 Key : Hypervisor.RootFlags.CreateVirtualProcessor Value: 1 Key : Hypervisor.RootFlags.DisableHyperthreading Value: 0 Key : Hypervisor.RootFlags.HostTimelineSync Value: 1 Key : Hypervisor.RootFlags.HypervisorDebuggingEnabled Value: 0 Key : Hypervisor.RootFlags.IsHyperV Value: 1 Key : Hypervisor.RootFlags.LivedumpEnlightened Value: 1 Key : Hypervisor.RootFlags.MapDeviceInterrupt Value: 1 Key : Hypervisor.RootFlags.MceEnlightened Value: 1 Key : Hypervisor.RootFlags.Nested Value: 0 Key : Hypervisor.RootFlags.StartLogicalProcessor Value: 1 Key : Hypervisor.RootFlags.Value Value: 1015 Key : Hypervisor.RootFlags.ValueHex Value: 0x3f7 Key : SecureKernel.HalpHvciEnabled Value: 1 Key : WER.OS.Branch Value: ge_release Key : WER.OS.Version Value: 10.0.26100.1 Key : WER.System.BIOSRevision Value: 5.3.0.0 BUGCHECK_CODE: 1e BUGCHECK_P1: ffffffffc0000005 BUGCHECK_P2: fffff807f93a32a0 BUGCHECK_P3: ffff98019b6ef2a8 BUGCHECK_P4: ffff98019b6eeab0 FILE_IN_CAB: MEMORY.DMP TAG_NOT_DEFINED_202b: *** Unknown TAG in analysis list 202b DUMP_FILE_ATTRIBUTES: 0x21800 FAULTING_THREAD: ffffd285b1093080 EXCEPTION_PARAMETER1: ffff98019b6ef2a8 EXCEPTION_PARAMETER2: ffff98019b6eeab0 BLACKBOXBSD: 1 (!blackboxbsd) BLACKBOXNTFS: 1 (!blackboxntfs) BLACKBOXPNP: 1 (!blackboxpnp) BLACKBOXWINLOGON: 1 (!blackboxwinlogon) (!blackboxwinlogonnotify) PROCESS_NAME: IntelConnectivityNetworkService.exe IP_IN_PAGED_CODE: nt!ExpPoolTrackerChargeEntry+40 fffff807`f93a32a0 f04b0fc12c06 lock xadd qword ptr [r14+r8],rbp STACK_TEXT: ffff9801`9b6ee1f8 fffff807`f95ad9ff : 00000000`0000001e ffffffff`c0000005 fffff807`f93a32a0 ffff9801`9b6ef2a8 : nt!KeBugCheckEx ffff9801`9b6ee200 fffff807`f96c9a66 : ffff9801`9b6eeab0 fffff807`f942b0e8 ffff9801`9b6ee880 fffff807`f92adb94 : nt!KiFatalFilter+0x1f ffff9801`9b6ee240 fffff807`f94f809c : ffff9801`00000002 ffff9801`9b6ef2a8 ffff9801`9b6e9000 ffff9801`9b6f0000 : nt!KeExpandKernelStackAndCalloutInternal$filt$0+0x16 ffff9801`9b6ee280 fffff807`f96b2a6f : ffff9801`9b6ef2a8 ffff9801`9b6ee880 00000000`00000000 00000000`00000000 : nt!_C_specific_handler+0x9c ffff9801`9b6ee2f0 fffff807`f92ac7b2 : ffff9801`9b6ee380 fffff807`f9000000 fffff807`f92adb94 fffff807`f90e67f4 : nt!RtlpExecuteHandlerForException+0xf ffff9801`9b6ee320 fffff807`f93deecf : ffff9801`9b6eeab0 ffff9801`9b6eefb0 ffff9801`9b6eeab0 ffff9801`9b6ef170 : nt!RtlDispatchException+0x2d2 ffff9801`9b6eea80 fffff807`f96bd545 : ffff9801`9b6ef1b0 ffff9801`9b6ef206 00000000`00000001 ffff8709`c8a79030 : nt!KiDispatchException+0x35f ffff9801`9b6ef170 fffff807`f96b8225 : 00000000`00000030 fffff807`f9b73850 ffff9801`9b6ef510 00000000`00000000 : nt!KiExceptionDispatch+0x145 ffff9801`9b6ef350 fffff807`f93a32a0 : ffff9801`9b6ef7f0 ffffd285`74100000 00000000`00000000 00000000`000001d0 : nt!KiGeneralProtectionFault+0x365 ffff9801`9b6ef4e0 fffff807`f92090d3 : 00000000`00000040 ffffd285`c342a070 ffffbc00`7d81bd50 00000009`00030001 : nt!ExpPoolTrackerChargeEntry+0x40 ffff9801`9b6ef530 fffff807`f9207cc2 : 00000000`00000000 00000000`00000591 00000000`34364d43 00000000`00000000 : nt!ExAllocateHeapPool+0x13a3 ffff9801`9b6ef690 fffff807`f9b7317a : 00000000`00000040 ffff9801`9b6efa10 00000000`00020019 fffff807`f9846f6e : nt!ExpAllocatePoolWithTagFromNode+0x52 ffff9801`9b6ef6d0 fffff807`f93d902d : 00000000`00000000 fffff807`f9845c4b 00000000`00000000 000000b2`d0ffcc18 : nt!ExAllocatePool2+0x8a ffff9801`9b6ef730 fffff807`f96f30b7 : ffff9801`00000016 ffff8709`c74bf790 ffff9801`9b6ef7c8 00000000`00000000 : nt!CmpAllocatePool+0x9 ffff9801`9b6ef760 fffff807`f99e8872 : ffffd285`00000007 000000b2`d0ffcc28 ffff870a`00000000 ffff8709`c74bf790 : nt!CmpAllocateParseContext+0x1b ffff9801`9b6ef790 fffff807`f96f308d : 00000000`00000000 00000000`00000000 00000000`00020019 ffff9801`00000000 : nt!CmOpenKey+0x1d2 ffff9801`9b6ef8b0 fffff807`f92adb94 : 00000000`00000000 fffff807`f96f3060 00000000`00000000 00000000`00000000 : nt!CmOpenKeyCallout+0x2d ffff9801`9b6ef8f0 fffff807`f92abde5 : fffff807`f96f3060 ffff9801`9b6ef9d8 000000b2`d0ffcd08 000000b2`d0ffcfb8 : nt!KeExpandKernelStackAndCalloutInternal+0xd4 ffff9801`9b6ef960 fffff807`f9a43820 : 000000b2`d0ffcc78 fffff807`f96bcb26 00000000`00000000 00000000`00000000 : nt!KeExpandKernelStackAndCallout+0x15 ffff9801`9b6ef9a0 fffff807`f96bca55 : ffffd285`b1093080 00000000`00000002 ffffd285`b1093080 00000000`00000000 : nt!NtOpenKeyEx+0x80 ffff9801`9b6efa20 00007ffd`856e25c4 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x25 000000b2`d0ffcc08 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffd`856e25c4 SYMBOL_NAME: nt!ExpPoolTrackerChargeEntry+40 MODULE_NAME: nt IMAGE_NAME: ntkrnlmp.exe STACK_COMMAND: .process /r /p 0xffffd285b060d080; .thread /r /p 0xffffd285b1093080 ; kb BUCKET_ID_FUNC_OFFSET: 40 FAILURE_BUCKET_ID: AV_nt!ExpPoolTrackerChargeEntry OS_VERSION: 10.0.26100.1 BUILDLAB_STR: ge_release OSPLATFORM_TYPE: x64 OSNAME: Windows 10 FAILURE_ID_HASH: {6f13343d-8edf-14f9-0269-6df067c74f57} Followup: MachineOwner ---------
This appears to be related to an issue under investigation on Microsoft's forums: https://learn.microsoft.com/en-us/answers/questions/5921413/recurring-0x1e-bugcheck-in-nt-exppooltrackercharge
It appears it is a crash being caused by faulty 275HX processors when they hit that particular instruction under some unknown precondition.
