16968 Discussions
Bug found in Intel driver and support assistant (23.3.25.6)
ajk89
Wasn't sure where exactly to post this, but it may help someone so here goes...
I have found a bug in Intel driver and support assistant.
If you install it, download and install the updates it recommends, it keeps a memory of your installs (c:\programdata\intel\dsa\install-history.json) which is fine.
But, if you then remove that driver and force a rescan with DSA, it detects that the driver version is older, but does not allow/offer to update it again, as it is in the install history it believes it has already been installed. A reboot of the system or service does not resolve this, nor does reinstalling the software, as the directory (c:\programdata\intel) persists between removal. It is possible the removal tool does remove this, but I haven't tried it. Pressing 'refresh results' in DSA does not help, and the tooltray app still remains green.
The workaround I have come up with is to stop the intel DSA services, delete the file (c:\programdata\intel\dsa\install-history.json), start the services again and relaunch the tray app. The scan and tray app now detect the outdated driver and offer to install again.
I hope this helps someone, and that intel fixes this in the future (maybe by having a button to clear the history in DSA, or a check in the software to see if the current installed version matches what it believes to be installed).
And yes, I know this is a niche problem, but with windows update pushing drivers out, there is a possibility of this scenario occuring.
I am on Windows 11 with the latest updates as of 21/07/2023, fresh installation.
DeividA_Intel
Hello ajk89,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with Intel® Driver & Support Assistant (Intel® DSA).
I will submit your feedback to the team, in charge so they can have it under consideration for future releases. However, I can't promise this change will be included in the near future.
I will proceed to close this thread, however, you can open a new one in case you need further support or if you face any issues with our products.
Deivid A.
