17357 Discussions
CLOCK_WATCHDOG_TIMEOUT
KPrad2
Specs:
Intel Core i5-7600K CPU @ 3.8 Hz 3.89 GHz
ASUS Prime Z270-A Motherboard
Nvidia GeForce GTX 1060 6GB
16 GB RAM
Windows 10 Home 64 bit
This is my first time assembling a PC and I think I might have screwed up. After installing the processor and locking it down, I accidentally spilt some thermal compound around processor housing, and some of it got onto the motherboard. To clean it properly, I took the processor off and tried wiping it off with a paper napkin. Unfortunately, a bunch of the processor pins on the motherboard got stuck to the paper napkin and in my panic to un-fuck the pins, I pulled so hard on the napkin that some pins were pulled out of shape (fuckkkk). I tried to push them back the best I could but the whole thing was clearly damaged. Figuring I had nothing to lose I went ahead with the build anyway.
After a lot of finger crossing and prayers - lo and behold, the PC magically managed to boot and install windows. Everything was working fine. Till it wasn't.
At random, I started getting the CLOCK_WATCHDOG_TIMEOUT blue screen. Things would just freeze till I physically rebooted. Lately I have been getting the MACHINE_CHECK_EXCEPTION error as well but it alternates with the CLOCK_WATCHDOG_TIMEOUT at random.
To fix, I have tried:
1. Updated each and every driver to the latest version off the OEM website.
2. Systematically tried to remove each component to see if the error was from some stray piece of hardware - I've removed and reinstalled the monitor, TV (through HDMI), video card and wifi card individually.
3. Tried running the processor on "Normal", "Low Power" (or power saver, whatever it's called), and "ASUS Prime" (or overclocked, don't remember the exact name). PC barely manages to boot in low power and can run the longest in the high power/overclocked mode.
So far nothing. Things run fine with low activity - browsing, watching a movie and such. But everytime I play a game for more than say 5 mins I get the same error again.
Is there anything I'm missing? Or have I truly fucked up? Do I need a new motherboard?
Hello SqPeg,
Thank you for contacting Intel Communities.
In this case, the only recommendation is to send the system to a computer repair shop so you can have a different motherboard tested or a different processor, this to rule out any failing component.
Juan Carlos
Hello SqPeg,
I was reviewing this thread and I wanted to know if you need further assistance.
If so, please don't hesitate in replying to this post if you need further assistance.
JC
KPrad2
You can close it, thanks.
