16992 Discussions
CPU(E3-1268L v5) - Display interface(VGA)
CChin15
Hi.
I have CPU E3-1268L v5(platform: Skylake-S) which has DDI port(dual mode displayport) and eDP port(embedded Displayport).
Which port should i use as i want to output the VGA signal(by using converter PTN3356).
Can i just use the DDI port or eDP port is a must(Which port is preferable)in this case?
My application is like this: CPU(DDI? eDP?)→converter→VGA connector
By the way, which signal is outputing from the DDI port as default?
TMDS(HDMI) or Main link(DP)?
