Hey, I have the i7-9700k and a clean Windows 10 Home (x64) installation (Version 1909 Build 18363.628). I have the exact same issue as the person in this thread:
https://forums.intel.com/s/question/0D50P00004VgcWe/easy-streaming-wizard-installation-failure
But I don't have any third party Antivirus software like Kaspersky that can be disabled and disabling the Windows Defender did not work for me.
Edit:
Attached SSU Scan Report and screenshot of the error message.
I managed to install the tool, but only by cheating the installation.
I logged the installation of the tool to see what might go wrong. In fact, the log looked to me like everything was working fine. So, I looked at the files in the folder "C:\Users\Username\AppData\Local\Temp\" which is mentioned in the log. There were two Python scripts used by the installer to perform a CPU check. A comparison with the created log, confirmed that my processor was indeed correctly detected.
The CPU comparison is performed online (easystreamingapi.intel.com) and gets a value back whether a usable CPU was found. In a text file, which is also located in the Temp folder and is called msiX.txt (where the X is assigned differently for each installation process), it should be noted whether the adjustment was carried out correctly.
There it says "RESULT_PROPERTY :<->: #0" from the beginning, which is interpreted as not supported CPU. The #0 would need to become #1 so that the installer knows that the CPU is supported. However, this file is not updated correctly, and the installation fails. I did not dig deep enough to see why the correctly detected CPU is not saved accordingly.
It is possible to manually open the text file after starting the installation, while the installer is checking the CPU, turn the #0 into a #1, and save the file. The installer will then continue the installation successful.
I will attach the anonymized log file to this reply to make it easier for your team to locate and fix the error.
Unfortunately, the log is mostly in German because the language of my computer is not set to English. Therefore, I hope my explanation is understandable, since English is not my primary language.
Kind regards
LBred
链接已复制
Every person's issue is unique. Don't make unfounded presumptions. Explain your problem, from the beginning, as if that person's issue didn't exist.
With the i7-9700k I have a CPU that is defnitly supported by the "Intel(R) Easy Streaming Wizard".
In my previous installation of Windows 10 Home (x64) it worked fine and had no issues at all.
I didn't change anything hardware related in my computer just made a clean new installation 2 days ago as I had some Windows issues regarding the Windows Update. Unfortunately it is not possible to install this software again now.
I get the message that the "Intel(R) Easy Streaming Wizard is not supported for this processor. [...]".
Some additional information about my machine are:
Mainboard: ASUS Z370-F
RAM: 16GB
GPU: NVIDIA GeForce RTX 2060
All current updates and drivers are installed as well as the most recent BIOS Update.
Ok, do not forget to turn them back on.
Download, run, and ATTACH the results of this utility (using the paperclip)
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then, an Intel support engineer can assist you.
Doc
Ah... I see that you are in legacy bios mode, which may well be the problem.
Now, you can convert to UEFI and GPT without rebuilding your system.
It involves running MBR2GPT, then a reboot to the bios to turn on UEFI. There are instruction out there that describe how to do it.
It may well be the cause. Even if not, it makes good sense to convert to GPT and UEFI.
Doc
Thank you for your answer.
My drive is already in GPT style. I just was in Legacy mode as "Wake on LAN" would not work for me otherwise. I switched of CSM and I am now in UEFI mode. Switched off the Windows Security again and it still does not work.
I think the Legacy mode should not be the problem here as the "Streaming Wizard" worked fine in my previous Windows installation.
Here is one such procedure to convert MBR to GPT and turn on UEFI:
https://www.tenforums.com/tutorials/81502-convert-windows-10-legacy-bios-uefi-without-data-loss.html
This link is provided for your convenience.
Doc
LBred, Thank you for posting in the Intel® Communities Support.
For this scenario, we recommend to uninstall the Intel® Easy Streaming Wizard from "Apps and Features". Once you do that, install the latest BIOS version provided by ASUS, I looked in ASUS web site and the latest one is 2401, please install it:
https://www.asus.com/us/Motherboards/ROG-STRIX-Z370-F-GAMING/HelpDesk_Download/
After that, install the Intel® Easy Streaming Wizard Version: 2.1.0807:
https://downloadcenter.intel.com/download/28889/Intel-Easy-Streaming-Wizard?product=186964
In that same link above, we can confirm as well that the Intel® Core™ i7-9700K Processor is supported by the tool.
Albert R.
Hello, thank you for your response.
I already have the latest BIOS Version and I cannot uninstall the Streaming Wizard as my problem is that it is impossible for me to install this software at all.
Kind regards
LBred
Hello LBred, Thank you very much for providing that information.
We will do further research on this matter, as soon as I get any updates I will post all the details on this thread.
Albert R.
Kind regards
LBred
Hello LBred, Thank you very much for letting us know those results.
Thank you very much also for sharing the solution to this case, we really appreciate that and we are sure it will be very helpful and useful for all the peers looking at this thread.
Any other inquiry, do not hesitate to contact us again.
Albert R.
