16910 Discussions
Cant update my driver?
IEnok
Hello, I attempted to upgrade my chipset from 13.2.0.1022 to 10.1.1.14
When its done i get the option to restart now or later. If i pick later it will say: failed. If i pick now i restart and when im back nothing has happened and i can start my intel driver update utility and try again.
I tried it around 4 more times but it still does not work.
I have Intel(R) Core(TM) i7-4700MQ CPU @ 2l40GHz 2.40GHz.
16GB ram.
GTX 770M.
Also do you think i will be able to play witcher 3 with these specs after i've updated my processor?
Hello Soffa1234,
The latest graphics driver for your system can be downloaded here:
https://downloadcenter.intel.com/download/26229/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen-?product=81496 https://downloadcenter.intel.com/download/26229/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen-?product=81496
If you get an error installing this driver I suggest you to uninstall the old driver and http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html manually install this version.
To update the chipset we will need your system model or you can access you system manufacturer website and get the chipset driver from their website which is the proper driver for your system.
To play witcher 3 you can check the minimum system requirements for this game at the following link:
http://en.cdprojektred.com/support/tw3-system-requirements/ http://en.cdprojektred.com/support/tw3-system-requirements/
NOTE: This link is being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Ivan.
IEnok
Hi, thanks alot for the help. I did as you said and downloaded the driver you linked me. How do i know if it worked or not? After i restarted i didnt see any errors or anything and i didnt see anything that said it worked. A cmd window poppde up and the window was called windows 32 or something, i waited a few sec and then it closed and thats all that happened after download. Is there somewhere to check if i have the new correctly installed?
To check if you have the latest driver installed right click on the desktop and select graphics properties, the Intel® HD Graphics Control Panel will show up click Options and Support then Information Center, you will see the graphics version installed. It should be 20.40.28.4501
Ivan.
IEnok
I have the version 20.19.15.4531. Its not the one you typed but its very close so i guess it doesnt matter? Thanks
Also when do i know if i should update my drivers? Im running the witcher 3: wild hunt with around 30 fps and i thought my specs were pretty good so maybe i need to update another driver?
The driver in your system can be update when you get Windows® updates, you system is fine to run Witcher 3; you can also see the system requirements for Witcher 3 here:
Ivan.
