Compatibility Query
CSing4
Hello.... I have HP Envy 6-1002tx Notebook PC.... It contains Intel Core i5-3317U @ 1.7GHz.... I want to buy the NFS-MW Limited Edition Pack which require following h/w
Minimum
CPU: Core 2 Duo 2.4GHz or Althon X2 2.7 GHz
Recommend
CPU: Quad Core CPU
My notebook fulfill all other requirements of this game. Only confused with CPU
So please tell me is this game is compatible with my Notebook or not. Also tell me Is there any issue with clock rate ??
Kevin_M_Intel
Hello Charan_Gill
Based on your description, this computer will be able to run the game due to the processor design and specifications.
When the processor needs a boost of power will utilize the Intel® Turbo Boos. This feature will increase the processor clock speed in order to complete the action faster. The processor normal clock speed of the processor is 1.7 GHz but it can go up to 2.6 GHz
You can check the processor comparison chart at the following link:
http://ark.intel.com/compare/65707,27250 http://ark.intel.com/compare/65707,27250
