17287 Discussions
Core 2 Duo T9300/T9500 processor compatibility
NFons
Hi
I'm new here in the community, so I ask for your understanding and help, if I'm not asking correctly, ok ?
Well, I would like to know, if Core 2 Duo T9300 or T9500 processors, are compatible with an Asus K50IJ laptop. I intended to replace your current Pentium Dual Core T4300, by one T9300 or T9500 ( that I have mentioned above ), to make it faster. I believe that they are compatible, because they have the same socket and FSB, but I do not know if BIOS is compatible. Can you give me your opinion ? My operating system : Windows 7 64 bit, 4 GB DDR2/800.
Thank you, and sorry for my bad english
Fonseca
Silvia_L_Intel1
Hello Fonseca,
Based on the chipset family and the support socket, we can say these 3 processors are backwards compatible. http://ark.intel.com/compare/33918,33917,37253 http://ark.intel.com/compare/33918,33917,37253
However, you will need to get in touch with Asus so they can let you know if the upgrade can be done or not.
Regards.
Silvia_L_Intel1
Hello Fonseca,
Regards.
