Cpu Temperature
ANowa5
Hello
I have like 77 Temp Cpu playing far cry 3 on ultra
i have msi z170a gaming gtx 970 msi 4gb gaming and intel i7 6700.
i tested temp by msi afterburner and it says 77C
i tested temp by speedfun and it says 65-70 C
so what can i trust ? and isn't that so hot ?
my pc is 1 week new
and when i go to drivers cpu it says that they are from 2009.
AdrianPL,
While you are playing a game, it's expected that your processor's temperatures increase; overheating could be the reason why your computer shutdowns. When your processor detects a max of temperatures a matter of security the processor it turns off the computer.
You can get some advice for overheating here: http://www.intel.com/content/www/us/en/support/processors/000005776.html http://www.intel.com/content/www/us/en/support/processors/000005776.html
Hope this helps you.
Hellen.
Hi AdrianPL,
Thought I would just check in and find out if you were able to resolve this, and if the information provided helps you
Hellen.
ANowa5
I have problem with
Intel® Driver Update Utility
it says your chipborad doesn't meet minimum requirments
Hi AdrianPL,
The tool is not working properly, and we are working on that; the only way is by updating the drivers manually.
Hellen.
If there is anything else you need, please let me know.
Hellen.
ANowa5
Yes
My driver from 21.04.2009 10.0.10586.0 is it good? Should i update or can i stay with this driver?
because i tried to install newest drivers and i can't install them
Hi AdrianPL,
I'm just following on this thread to ask you if the information provided above helps you.
Hellen.
