17248 Discussions
DDR5 Quad kit for 13th gen core.
CarlSpencer
Hello intel co.
I got a questions for intel 13gh gen i series core.
I'm already using i5 13600K on Z790 board with DDR5 16GB 5600Mhz mem dual kits.
I'd like to upgrade DDR5 mem space for workload, so two of DDR5 16GB 5600Mhz mem will be buy to set 64GB mem space.
If when set four of 64GB mem sets. How frequency it be?
IsaacQ_Intel
Hello @CarlSpencer
Based on the information from the official website Ark:
·      Max Memory Size (dependent on memory type): 192 GB
·      Memory Types: Up to DDR5 5600 MT/s, Up to DDR4 3200 MT/s
Remember, in all modes, the frequency of system memory is the lowest frequency and latency of all memory modules placed in the system, as determined through the SPD registers on the memory modules. The system memory controller supports a single DIMM connector per channel. If DIMMs with different latency are populated across the channels, the BIOS will use the slower of the two latencies for both channels. For Dual-Channel modes, both channels should have a DIMM connector populated. For Single-Channel mode, only a single channel can have a DIMM connector populated.
Additionally, it's important to consult the motherboard's manufacturer to determine its maximum supported RAM capacity.
Isaac Q.
IsaacQ_Intel
Hello CarlSpencer
We hope you are doing fine.
Isaac Q.
IsaacQ_Intel
Hello CarlSpencer
Best regards.
Isaac Q.
