16967 Discussions
Dell D830 Intel965 chipset with T9800 processor
Hi all,
I have question, i have Dell D830 laptop with chipset Intel 965, from datasheet it work with FSB 1066 , so i can put T9800 processor, right? But problem with memory it will only work by FSB 800.
Or only what i make with processor is T9500.
Dell dont know any, they simply says that i can only put T7800.
Thanks for answer
Alex
DMorr2
This guide might be of help for people attempting to do the same thing:
http://forum.notebookreview.com/hardware-components-aftermarket-upgrades/209284-intel-mobile-processor-compatibility-guide.html Intel Mobile Processor Compatibility Guide
It might also help to know that I tried a working Intel P8700 processor in a Dell D830 and it did not work; I strongly suspect because the processor is 1066 Mhz and suspect the 965 chipset does not support front system bus speeds of 1066. I have not spent enough time verifying whether the chipset will support 1066 bus speeds, but my failed attempt tells and the compatibility guide seem to indicate that it does not.
I hope this helps someone.
