16902 Discussions
Dell Latitude 7200 i7 10610U and Latitude 5210 i5-8365U PL1 throttling
SamR1
I have a bunch of Dell 7200s that are getting throttled to .4GHZ due to Package-Level RAPL/PBM PL1. I have tried everything I can think of to resolve this issue. One way it will speed up for a little while is to unplug and re-plug the OEM charging cable. I have tried rolling back the Intel dynamic platform/Thermal firmware, Installing Dell Power manager to turn the performance up to Ultra, disabling speedstep, updating all drivers/BIOS. I have confirmed that the core temps are around ~50-60C during this performance issue. I'm seeing around 15-20% CPU usage and 20% frequency. I've tried disabling esifsvc, I've verified Group Policy/Registry values. and at this point I'm running out of ideas. Is anyone else seeing these types of issues on with Mobile processors?
Mike_Intel
Hello SamR1,
  1. Was it working fine before?
  2. What was the last change made in the systems before the issue started?
  3. You mentioned that the latest BIOS was installed and still the same? Let me check, how is the temperature of the processor?
  4. Have you tried contacting Dell regarding this issue? To be honest, our support is very limited for this system since everything is controlled by their BIOS.
Michael L.
SamR1
I am currently in the process of getting with Dell support. I wanted to make sure that I wasn't missing anything on the Intel side of the problem as well.
Mike_Intel
Hello SamR1,
Thank you for the update.
I am glad to hear that. You can further check with them to diagnose the issue and update us here on thread too,
Michael L.
Mike_Intel
Hello SamR1,
I am just checking if you are now talking to Dell for further troubleshooting.
Michael L.
Mike_Intel
Hello SamR1,
I am sending another follow up hoping that Dell is now assisting you with this issue.
Michael L.
SamR1
Dell has been unable to provide a solution, and they are recommending replacement.
This is the only thing that I can find that might be on Intel's side that could be causing the symptoms.
SamR2
One way i've been able to recreate the problem is to stress test the machine for 5 or so minutes, and reboot the tool. The machine will stay at 400 mhz until I unplug/replug the charger, or it gets stuck at 400 mhz for an extended period no matter what I try. (hour at least)
