16995 Discussions
Dell inspiron 15 5584 cpu stuck at 0.4 Ghz
Sabbir
HI everyone. Recently after a startup my Dell inspiron 15 5584 laptops i7 8565u cpu got stuck at 0.40 Ghz. I have tried everything including Bios upgrade, CMOS reset, Clean Installation of W11, Updated Drivers,etc. Ran all sorts of diagnostics and found nothing. I tinkered with the intelppm driver registry and changed the start value from 3 to other numbers. CPU then runs at base frequency and Turbo boost doesn't work. But that is not a solution.
After checking with intel SSU I found something that doesn't make sense.
Intel(R) Core(TM) i7-8565U CPU @ 1.80GHz"
Architecture:"x64"
ATPO:"Not Available"
Caption:"Intel64 Family 6 Model 142 Stepping 12"
- "Chipset Name":"Intel(R) Core(TM) i7-8565U CPU @ 1.80GHz"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Core+i7+8565U+CPU+"
CPU Speed:"1.79 GHz"
Current Voltage:"6. volts"
Driver:"Not Available"
Driver Date:"04/21/2009 12:00 AM"
Driver Path:"C:\Windows\system32\drivers\intelppm.sys"
Driver Provider:"Microsoft"
Driver Version:"10.0.22621.3672"
Ext. Family:"Not Available"
Family:"Intel Core™ i7-2760QM"
FPO:"Not Available"
INF:"cpu.inf"
INF Section:"IntelPPM_Inst.NT"
Install Date:"Not Available"
Last Error Code:"Not Available"
Level 1 Cache:"4 x 256 KB"
Level 2 Cache:"4 x 1024 KB"
Level 3 Cache:"8 MB"
Load:"100%"
Manufacturer:"GenuineIntel"
Model:"142"
Name:"Intel(R) Core(TM) i7-8565U CPU @ 1.80GHz"
Number of Cores:"4"
Number of Cores Enabled:"4"
Number of Logical Processors:"8"
Part Number:"Not Available"
Power Management Capabilities:"Not Available"
Power Management Supported:"No"
Processor ID:"BFEBFBFF000806EC"
Revision:"Not Available"
Serial Number:"Not Available"
Help pls...
Caguicla_Intel
Hi Sabbir,
Kindly provide the following details to help check your request.
  1. When did you notice the issue?
  2. What is it that you found on SSU that doesn't make sense?
  3. Does it go higher than 0.40 Ghz when doing any heavy workload?
  4. To ensure your processor is operating as expected, I suggest running the Intel Processor Diagnostic Tool (IPDT). This tool will help confirm the health and functionality of your processor.
Caguicla C.
Sabbir
Hi Caguicla,
Thanks for reaching out.
1. It all started about two weeks ago. I used the laptop at night, shut it down and the next morning it was struggling to boot up. It was all laggy and slow. But it booted and I noticed the task manager where it showed 0.40 Ghz only.
2. Power Management Capabilities:"Not Available"
these are what don't make sense to me from SSU
3. At heavy load it does not go above 0.40Ghz or 20 percent utilization. In fact it is not capable of taking heavy load anymore. Frames on online games does not even go above 9 or 10 fps. Previously it could show 58 to 60 fps continuously.
4. Attached here is the report from IPDT and a screenshot of the task manager while running the tests-
Thanks a lot again.
Just to make sure, I even downgraded to windows 10, it was a clean installation. yet the results are same.
Caguicla_Intel
Hi Sabbir,
Thank you for your reply.
I'll check this request internally and give you an update as soon as possible.
Caguicla C.
Caguicla_Intel
Hi Sabbir,
Thank you for your patience on this matter.
Upon reviewing the test results, it appears that all tests have passed, suggesting that the CPU is functioning correctly. However, to further assist you with the ongoing issue, I would like to offer some additional recommendations that may prove helpful:
1. Adjusting Power Options:
• Navigate to the Control Panel and access the Power Options.
• Review the current power plan set on your laptop. If it is set to the Balanced Power Plan, consider switching to a different plan to see if the issue persists.
2. Optimizing OS Power Settings:
• Go to Power and Sleep Settings, then to Additional Power Settings.
• Proceed to Change Plan Settings and then to Change Advanced Plan Settings.
• Locate Processor Power Management and adjust the settings to ensure the CPU is set to maximum performance.
3. Verifying BIOS Settings:
• Within the BIOS, verify if Intel® Turbo Boost Technology is enabled.
• It is advisable to use the BIOS default settings. Please consult with the Original Equipment Manufacturer (OEM) for guidance on modifying BIOS values.
4. Ensuring OS Updates:
• Check for any pending OS updates and install them to keep your system up-to-date.
Should the issue continue after these steps, it may be necessary to reach out to the OEM, as the problem could be related to hardware within your laptop.
Caguicla C.
Caguicla_Intel
Hi Sabbir,
I'm following up to check whether you have had the chance to review our prior correspondence. If you have, kindly acknowledge receipt and do not hesitate to reach out if there are any aspects you'd like to discuss or require further explanation on.
Caguicla C.
Caguicla_Intel
Hi Sabbir,
As we have not heard from you for the past few days, we will go ahead and close this thread. If you need help in the future, please submit a new question as this thread will no longer be monitored.
Caguicla C.
jhonCedeno
Hola.
Tengo el mismo problema y he realizado las mismas recomendaciones, para añadir he realizado pruebas de estres al cpu pero solo se limita a los 400Hz, me puede ayudar con la solucion o direccionandome donde puedo llevar mi equipo para que lo solucionen.
