						I am running a core due intel chip (Lga775) on a arktek G41m motherboard running windows xp embedded sp2. This is z new build and simply cannot find the correct drivers for this combination. Any positive help greatly received.
Drivers from another make of motherboard with the same chipset might install on your system. For example the Gigabyte GA-G41M-Combo motherboard drivers page can be found here . There is also a CPU Support list for this Gigabyte board on this page .
						Thank you. Seems like a good place to start.
