ESIF IPF time error
Sp2222
I've been getting this error around every 18 hours since I freshly installed windows, and drivers on my laptop, how can I go about fixing this?
ESIF(1.0.11904.2707) TYPE: ERROR MODULE: IPF TIME 65259234 ms
[<IPFSRV>AuthMgr_EsifSetConfig@ipfsrv_authmgr.c#1866]<65259234 ms>:
Unauthorized EsifSetConfig: override:/nopersist/IETM.D0/_art
I am unsure of what exactly is causing this error.
ASUS Laptop: Intel Ultra 9 285h (32GB ram).
Sorry for the lack of details.
Jonzyl_Intel
Thank you for reaching out.
I understand that you're experiencing ESIF IPF time errors every 18 hours since your fresh Windows installation on your ASUS laptop with Intel Ultra 9 285h.
To better assist you, I need some additional information:
  • Did you install Intel XTU or any ASUS utilities like Armoury Crate during your setup?
  • Could you check if this error appears in Windows Event Viewer under System or Application logs? (If yes can you provide it for us)
  • Are you running the system with default BIOS settings or have you made any power/thermal modifications?
  • Does the error occur at the same time each day or exactly 18 hours after boot?
  • Are you experiencing any performance issues, thermal throttling, or system instability alongside this error?
  • Could you check Task Scheduler for any Intel or ASUS related tasks that run periodically?
  • What power plan are you currently using (Balanced, High Performance, or custom)?
  • Have you installed any third-party monitoring software like HWiNFO, MSI Afterburner, or similar tools?
  • What are your CPU and system temperatures when this error occurs - are they running hot or within normal ranges?
This information will help me determine the cause and provide appropriate troubleshooting steps.
We're looking forward to your response.
Best regards
Jonzyl B.
Jonzyl_Intel
Hi Sp2222,
I just wanted to follow up to see if you had a chance to review the information I posted. Your feedback at your earliest convenience would be greatly appreciated. Thank you.
Best regards
Jonzyl B.
Jonzyl_Intel
Hi Sp2222,
Best regards
Jonzyl B.
Jonzyl_Intel
Hi Sp2222,
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Best regards
Jonzyl B.
