17079 Discussions
Elkhart Lake: Driver for internal ethernet controller
MiguelFernandes
We use the Elkhart Lake CPUs (Atom - x6212RE) in an embedded solution, where we need to run a Real-Time OS (RTOS-32) with limited availability of Ethernet drivers.
By default, the OS doesn't recognize the ethernet controller in the Atom-x6212RE, and we're thinking of testing/adapting any of the available drivers for other Intel ethernet controllers.
The available drivers are for the following controllers:
  • 82575, 82576, 82580, 82598, 82599,
  • i210, i211, i350, i354, i225,
  • X540, X550, EG20T
Should any of this be compatible to the controller in the Atom-x6212RE (Elkhart Lake)?
Thank you very much!
MiguelFernandes
Any indication of compatible driver (or close to being compatible) would be most welcome.
