17536 Discussions
Embedded Options available
What does it mean by Embedded options available YES?
That generally means a CPU, for example, is suitable and is supported for use in a non-home PC environment. For example, if an industrial machine of some kind needs a CPU to control it, embedded option products could be used in that application. It also means that the CPU manufacture will provide support for the product for a longer period of time, and at a level beyond that of the home PC user environment.
thanks, was searching for a sensible and logical answer since quite somewhile
