Framework Laptop
redscarelett
Hello Community
I'm reporting an error on XTUSetup.exe when I try to install it. The laptop processor is 11th Gen. i5 core 1135G7. Since the Acer Nitro 5 which has a 9th GEN. i5 core 9300H install cleanly this morning. I read other whom has this issue, to summit a SSU.exe report. The report shall be attached here.
I hope for a solved solution down the road. This is a new type of concept design, sustainable and repairable.
Regards: Redscarelett
AlHill
Neither the i5-1135G7 or the i5-9300H are on the XTU supported processor list.   XTU only supports X and K processors, of which you have neither.   And, as it says on the XTU download page, "Intel XTU may or may not work on unsupported processors."
[Windows 11 is the new Vista]
AlHill
redscarelett
XTU can benchmark, stress test. Intel i5 9300H, and log it in HWBot web site.  I do accept 2/3 of the solution, if read the txt file you see framework or netframework45  will not response. Human error in choosing a laptop name.
AndrewG_Intel
Hello @redscarelett
We are checking this thread and we would like to mention that the information provided by AlHill is correct. As this is noted in the Download website, Intel® Extreme Tuning Utility (Intel® XTU) may or may not work on unsupported processors. Please refer to the section "This download is valid for the product(s) listed below." for a list of supported processors.
If you are looking for a tool to monitor and benchmark your system, including the processor, we recommend checking with your Computer Manufacturer for a specific tool validated for your system, especially if this is regarding Mobile systems (laptops, tablets, etc).
Having said that, we will proceed to close this inquiry now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andrew G.
