17483 Discussions
Help, computer keeps blocking
Jackfili
My computer keeps blocking and when I go to the event visualizer the last event is this:
Timeout (30000 millisecondi) durante l'attesa della connessione del servizio Intel(R) SUR QC Software Asset Manager.
pressed_for_time
Valued Contributor III
The Intel(R) SUR QC Software Asset Manager is a Windows service that is part of the Intel Computing Improvement Program (ICIP) offered as an option when installing the Intel Driver & Support Assistant (DSA).
It is only active if you accepted the offer to join the ICIP during the DSA install. To decline involvement you first need to look for the Intel DSA icon on the taskbar. Then right click on the icon (see graphic below)
Select Intel Computing Improvement Program and this screen will appear
Click on Decline to turn off the service. This should remove the error message and the associated issues.
