16916 Discussions
How to check Processor type and speed, as I only have laptop processor chip and some alpha numeric numbers embossed
SJain28
Intel Processor
4H422063A3174
M C 11 V422C152 SR1EN
M22381 01 S65
AlHill
I was able to look up your processor using SR1EN that you supplied:
http://ark.intel.com/products/81018/Intel-Core-i3-4030U-Processor-3M-Cache-1_90-GHz Intel® Core™ i3-4030U Processor (3M Cache, 1.90 GHz) Specifications
Doc
AlHill
You can run the https://downloadcenter.intel.com/download/7838 Download Intel® Processor Identification Utility - Windows* Version
or you can use a utility such as http://www.cpuid.com/softwares/cpu-z.html CPU-Z | Softwares | CPUID
If you are unable to use these tools, one of the Intel support staff may be able to help with looking up the information you provided.
Doc
AlHill
Doc
YashJ, please refer to the previous post, Al_Hill provided the correct answer; based on the spec code "SR1EN" you have a http://ark.intel.com/products/81018/Intel-Core-i3-4030U-Processor-3M-Cache-1_90-GHz# @ordering Intel® Core™ i3-4030U Processor (3M Cache, 1.90 GHz) Specifications.
Amy.
