How to know?
Noobi
I Have i913900k I put Intel default performance mode.
I changed turbo ratio to 5.6ghz from 5.8ghz on 2 pcore and 6 pcore put 5.4ghz.
I dont see it pump to 5.6ghz when gaming I see all 5.5ghz.
I use hw monitor and in max is.
I turn off e cores.
Temps are 70-88°c
IS turbo needed for gaming csgo 2.
How is best to setup good performace with i913900k.
I have 32gb (2x16gb)
Ddr5 7600 g.skill I only us 5900mhz and use xmp1
I see in task manager memory is 5900 but during xtu extream benchmark It show 4500-4900mhz.
Not sure what needs changes in bios mostly is on auto.
I disable eist and hyper threding and c state control and turn on Resizable BAR support.
KennethB_Intel
Hello Noobi,
Thank you for reaching out to Intel Community and sharing the details of your current setup. Based on the information provided, here are some recommendations to help you achieve optimal performance:
  1. Turbo Boost is beneficial for gaming because it allows higher single-core performance, which many games rely on. I recommend keeping Turbo Boost enabled for the best results.
  2. If you are not seeing the expected turbo ratios, it may be due to workload distribution or power limits. Leaving most frequency settings on default is generally best for stability and performance.
  3. The difference between Task Manager and XTU readings can occur because of how benchmarks report effective speeds. Ensure XMP is properly applied in BIOS and confirm that the memory runs at the intended speed.
  4. Disabling EIST, Hyper-Threading, and C-State can reduce efficiency and may not improve gaming performance. I suggest enabling these features for balanced performance and power management.
  5. Your reported temperatures (70–88°C) are within safe limits, but if they remain high under load, consider improving cooling solutions for sustained performance.
  6. Keeping Resizable BAR enabled is good for modern games that support it.
Please let me know if you have any other questions.
Kenneth B.
KennethB_Intel
Hello Noobi,
Just checking in to confirm if you have reviewed the details I shared. Your response would be appreciated so I can proceed with the appropriate support.
Kenneth B.
KennethB_Intel
Hello Noobi,
As I have not received a response, I will now proceed to close this inquiry. If you require further assistance, please feel free to submit a new inquiry, as this thread will no longer be monitored.
Kenneth B.
