16991 Discussions
I can change my netbook processor with Intel ® Atom ™ processor N455 (512K Cache, 1.66 GHz) and replace it with Intel ® Atom ™ Processor N2800 (1M Cache, 1.86 GHz)?
ATorr7
I've been thinking about changing your processor is compatible with the intel processor N2800?
Silvia_L_Intel1
Hello Agustin, thanks a lot for contacting us through the Intel Communities.
I would like to inform you that the 2 sockets are pin compatible; any of those processors will fit on your board.
However, I would recommend you to check with the laptop manufacture if this combination is possible, before getting the N2800 processor. Please check if this CPU is fully supported by their laptop and if they allow this kind of modification.
Sometimes, if you make changes on OEM systems, the product is not going to be covered under warranty anymore.
This link compares the two processors
http://ark.intel.com/compare/58917,49491 http://ark.intel.com/compare/58917,49491
ATorr7
Thanks for your reply, where I find the intel atom N2800?
I'm already in contact with the manufacturer, only I have to wait your answer, My Motherboard is Intel powered classmate PC chipset: Intel nm10
Note: is a netbook of Argentina
Silvia_L_Intel1
The N2800 is not available as a boxed unit. It is a 'Ball Grid Array' part (FCBGA in the specs) so it must be soldered to the motherboard by the system manufacturer.
ATorr7
So is advisable to change the motherboard with the intel processor N2800?
Silvia_L_Intel1
It will be necessary to change the system complete.
Which is the model number of the netbook you have with the N455?
ATorr7
i don't have the model number,but yes the specifications
Technical specifications
Supplier : Coradir
Make / Model : CDR
Shell Color: Black
Processor: Intel ® Atom ™ processor N455 ( 512K Cache , 1.66 GHz , )
Form Factor : Clamshell
Motherboard: ECS Model E11IS1 with Phoenix bios & PnP ACPI 2.0
Operating System:Windows XP ®
Chipset: Intel ® NM10
Display : 10.1 " 1024 × 600 WVGA LCD Anti Glare
Input Devices : Keyboard 84 keys ergonomic
Language: Spanish
Waterproof keyboard . Touchpad with option bars @ > 200dpi
RAM: 1GB DDR3 667Mhz
Hard Drive: Hard Drive 5400rpm 2.5 " 250GB (SATA )
Connectivity 10/100 Full- Duplex Ethernet , IEEE802.3u onboard Realtek 8103EL - 100BaseTX
Wi fi 802.11 b / g / n
Security Options : Kensington Lock Slot, TPM embedded security chip 1.2 HDD protection. Chance of Blocking Setup and BIOS boot password
Expandability : Card reader : SD ; SDHC ; MMC memory card USB 2.0 interface. CR Support Unit
Collaboration: Audio Codec Realtek ALC269 -VB onboard , 24-bit , 2 builtd -in speakers , Internal Microphone, 300K Web Camera , high resolution 640 × 480 @ 30fps
Ports 3 x USB 2.0 ports 1 x RJ -45 LAN ( UTP ), 2 x Jacks for Micro-in/auriculares , 4 in 1 SD / MMC / MS / MS Pro memory card support , 1x D -Sub VGA port 15Pin
Power: 6-cell battery : 4400mAH Li -ion , Delta Electronics ADP- 40PH Model -AB 40W AC Adapter , 50 -60Hz 100/240V AutoSwitch
Silvia_L_Intel1
Agustin, this is all I found regarding your computer. http://www.coradir.com.ar/ Coradir S.A.
It will be necessary to contact the system manufacture in order to find out if the processor can be changed.
