16898 Discussions
I have a 80C186EC-25 and are IID Supply Current in Idle Mode and IPD Supply Current in Powerdown Mode For IID Idle Supply Current, I measure roughly 115mA. The limit for this test is 92mA. To setup I write to the PWRCON register to put the device into t
EDolf
I have a 80C186EC-25 and are IID Supply Current in Idle Mode and IPD Supply Current in Powerdown Mode For IID Idle Supply Current, I measure roughly 115mA. The limit for this test is 92mA. To setup I write to the PWRCON register to put the device into the proper mode, and then give the device a Halt instruction. For IPD Powerdown Supply Current I measure roughly 115mA with a limit of 100ua. To setup I write to the PWRCON register to put the device into Powerdown Mode and then give the device a Halt instruction. The bus cycles stop, and the CLKOUT pin stops toggling which is supposed to happen in Powerdown Mode, so it appears I have the device setup properly, but the current does not drop like it should. Any documentation or app notes that would help!
Alberto_Sykes
Hello EDolfi:
I just wanted to let you know that in order to get support for this type of product we do have an specific department, in there you will be able to get all the information related to 80C186EC-25 product, here is the link where you will be able to contact them:
https://www.rocelec.com/ https://www.rocelec.com/
Alberto
