16907 Discussions
I'm building a new desktop using an Intel i3-4370 processor (my first Intel in a while) and the pictorial instructions do not show thermal paste. Does this mean thermal paste is not required?
JOHar
The i3-4370 pictorial instructions for processor installation do not include the application of thermal paste. This is my first experience with an Intel i cpu, so I am a bit confused about using thermal paste on it. Does the fan design obviate the need for paste?
ppara5
Valued Contributor I
CPUs, both Intel and AMD, require thermal paste. The instructions should have mentioned that. By the way, you only need a blob about one cm in diameter. Using too much is as bad as using too little.
JOHar
Thanks. I thought so, but wanted to be sure.
