I7 4790k
So I just bought an i7 4790k and I'm having overheating problems (45°c idle- around 85-90 °c gaming or with stress test) I already updated bios to the latest version, checked the stock cooler, but nothing works.
My specs:
Asus Maximus VII Ranger
Kingston HyperX Fury 4gbx3 1600MHz
SSD Kingston 240gb with Windows 10 Pro
Evga GTX 970 4gb
AP16
Valued Contributor III
stock cooler
You purchased CPU in boxed package, right?
IUman
Hello bren94,
Thank you for joining the Intel communities.
We have seeing over heating problem with this unit before and most of the customers were able to solve the issue following the steps here:
Yes i already tried with that and only make it worst. And yes it was a boxed package
Ivan_U_Intel
Hello bren94,
Is the system over clocked?
Could you please post the RAM part number?
Make sure your RAM is running at 1333/1600 MHz, DDR3L-1333/1600MHz @ 1.5V
Also, I recommend applying new thermal paste on the processor, are you using a liquid cooler or the heatsink.
Please run the https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool-64-bit- Intel® Processor Diagnostic Tool
I will appreciate if you could provide me with the result.
No, its not overclocked and i already changed the thermal compound twice. Also im currently using the stock heatsink
