16871 Discussions
I9 9900k unstable mhz issues. Help please
mball6
Hello guys , I have followed this video
https://youtu.be/jOXH2YIMi2Y
for overclocking my i9 9900k on the maximus xi extreme but something is wrong.
The mhz is not stable at all
I need help guys. I am not sure what is going on with my brand new i9 9900k.
https://streamable.com/ybers
The overclock is to 5100 mhz but why the numbers are not stable to 5100 mhz but they go down to 800 mhz?
Is there a problem with my cpu?
The testing scores are horrible
https://ibb.co/d4qy6TS
What am I doing wrong?
My cooler has 167 pts .
Leonardo_C_Intel
Hello mball6 Thank you for posting in the Intel Community. Please bear in mind that altering clock frequency or voltage may damage or reduce the useful life of the processor and other system components, and may reduce system stability and performance. Product warranties may not apply if the processor is operated beyond its specifications. You can refer to the following link for more information about overclocking (https://www.intel.com/content/www/us/en/gaming/overclocking-intel-processors.html), in case you will like to overclocked the system we recommend the use of the performance tuning protection plan (https://click.intel.com/tuningplan/). Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
BGree7
I noticed that you linked to the Intel Performance Tuning Plan website and recommended the purchase for this customer's i9-9900K.
Did you happen to notice that Intel hasn't added the option to buy this plan for the CPU in question? I also notice that the i7-8086K was never added.
Leonardo_C_Intel
Hello mball6 I was checking your case and would like to know if the information provided was helpful. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
ZPett
This chip does not need an overclock. Your motherboard is an Asus z390 type? I have heard rumors that the Asus z390 VRM's aren't quite up to par for a 5 ghz+ chip. To overclock the 9900k, you need exceptionally good VRM's (Voltage Regulator Modules) to attain overclocked chip stability. I did my research and bought a Gigabyte z390 in case in the future (after warranty expires) I want to experiment with overclocking. This chip is already at a very high ghz stock. Don't worry. This chip does not need an overclock. If you do, you will need a serious cooling solution and an exceptional power supply or you won't get anywhere because the chip will only throttle down its ghz to avoid melting. This chip can pull close to 300 watts on its own. The Nvidia RTX 2080 ti is at 279W full load. The 9900k can pull 180 - 200 watts at 5 ghz full load on all 16 threads according to my system diagnostics. Mainstream CPU's don't usually take more juice than graphics cards. Higher Ghz means more juice needed per time-step (with chip of same nano-meter sized architecture). Good VRM's are needed to regulate higher voltages into this already power hungry chip.
Leonardo_C_Intel
Hello BGree7 Thank you for posting in the Intel Community and for pointing out these details, I am going to send this feedback through. Hope this helps. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
Leonardo_C_Intel
Hello BGree7 Thank you for waiting. Bear in mind that the site https://click.intel.com/tuningplan/purchase-a-plan list the only models covered to date, but we'll forward this feedback to the right department for consideration. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
