I914900KS
hallo000de-ti
Ich kann die ON Board Grafik nicht Aktivieren. Board ist Asus Maximaus Z790 Hero.
Ideen?
Danke
pressed_for_time
Valued Contributor III
On ASUS motherboards the BIOS section dealing with graphics is normally found at Advanced->Advanced->System Agent (SA) Configuration->Graphics Configuration. There is a setting called iGPU Multi-Monitor that is set to Disabled by default, this needs to be set to Enabled. The other setting that will be found here is Primary Display, this should be set to Auto.
