Hey, I want to upgrade the OS on my pc from Windows 10 to Windows 11. The CPU that is installed does not have the TPM 2.0 security option. I want to upgrade the CPU, but i don't know which CPU is compatible. This is the CPU that I have now: Intel(R) Core(TM) i7-4558U CPU @ 2.80GHz 2.80 GHz I hope there is a solution for it.
There is no solution unless you change your motherboard and processor to something that supports an 8th gen processor or later.
Or, if you ues a hack to install W11.
[If you find any Intel driver you might need, download and save it now.]
Thx for the answer.
To bad that I will need to replace the motherboard as well.
Think I will need to search for another way to get W11 installeren.
Topic Options
