17478 Discussions
Intel Core Processor Gen3 Memory Data Sheet
RShuf
The later generations have data sheets posted for their memory locations. Does anybody know where the memory locations guide for the 3rd Generation Intel Core Processors is? I am specifically trying to find the memory address for the temperature sensor in the processor.
Hello Rashuff,
Thank you for joining the Intel Community Support.
I understand that you would like to find the memory address for the temperature sensor in the processor.
Could you please let us know if you are developing hardware/software?
Is there a specific reason why you would like to get this information? This will allow us to address your question properly.
Wanner G.
RShuf
I am developing Software. I want the address for the temperature sensor so I can monitor the temperature.
RShuf
I saw the Thermal Monitor Locations (TM1 & TM2), but I was hoping to read the specific temperature.
n_scott_pearson
The processor's temperature configuration (Tcontrol Offset and Tjmax values) can be read from the IA32_TEMP_TARGET Model-Specific Register (MSR). The processor's per-Core thermal status and temperature readings can be read via the IA32_THERM_STATUS MSR. Finally, the package-level thermal status and temperature reading can be read via the IA32_PACKAGE_THERM_STATUS MSR. All of these MSRs and their access are discussed in Volumes 3 and 4 of the https://software.intel.com/en-us/articles/intel-sdm Intel® 64 and IA-32 Architectures Software Developer Manuals.
Hope this helps,
RShuf
Thank you for the response, this is extremely helpful. Both the IA32_THERM_STATUS MSR and the IA32_PACKAGE_THERM_STATUS MSR reference the Package TCC (Thermal Control Circuitry) Activation Temperature; do you know where this information specific to the 3rd Gen core Processor can be found?
I checked the 3rd Gen DataSheet.
The Thermal and Mechanical Guidelines for this processor(3rd gen) is not posted online(link does not work), I did not know if it was supposed to be in there.
n_scott_pearson
The TCC Activation Temperature is (also) the Maximum Junction Temperature (Tjmax). You read its value from the IA32_TEMP_TARGET MSR.
Yea, there always seems to be a couple of links on this page that are broken. Could the ICS folks (intel_corp) please request that these links be fixed. We are talking about this page: https://www.intel.com/content/www/us/en/processors/core/core-technical-resources.html Intel® Core™ Processors Technical Resources.
