16882 Discussions
Intel Core i5-14600kf possible instability issues?
Anonymous
Not applicable
I have been having a lot of micro stutters and lags, even crashes
I've tried updating my drivers, Factory Installed my windows, Tried optimizing my computer but nothing works
My cooling is very good, doesn't exceed 60C
And my specs are compatible
I still keep having performance issues
My specs:
Intel Core i5 14600KF
32GB Corsair Vengeance LPX RGB 3600MHz (2x16)
B760I AORUS PRO DDR4
GeForce RTX™ 4060 Ti StormX 8GB
Samsung SSD 980 PRO 500GB
Is there any bios settings i should set on for performance or better stability so i can fix the issues im having?
Intel staff please answer
NormanS_Intel
Hello Anonymous,
Thank you for posting in the Intel Community!
I'm sorry to hear about the issues you're experiencing with your computer. To clarify, have you updated your BIOS to version F12, which includes microcode 0x12B, and set the Intel Default Settings? If not, I recommend installing the latest BIOS version from this link. If the issue persists, there may be a possibility that your processor is faulty.
Additionally, you can try disabling the "Turbo" feature in the BIOS. If the instability stops with Turbo disabled, it is likely that the processor is affected.
Norman S.
