17514 Discussions
Intel Driver Update Utility: System.ArgumentException
MB9
Dear Intel community,
I would like to update my Intel Chipset Device software from version 6.3.9600.17238 to 10.0.24. My processor is the Intel Core i5-2400.
When I downloaded and installed the driver with the Update Utility, the program says that it failed updating, while the installers says it succeed. (What isn't correct.)
When I checked the program logs, I saw this error:
DriverUpdateUI.exe Error: 0 : Failed to install for driverId 24165
DriverUpdateUI.exe Error: 0 : System.ArgumentException: Proces with id 7164 couldn't be executed.
bij IDUUInstall.IDUUInstall.InstallDriver(DriverInfo di)
bij Driver_Manager.DriverManager.InstallDriver(Int32 driverID)
It's a developing mistake. I hope you can fix this System.ArgumentException, so I can update my Intel Chipset driver.
PS: I also tried manually installing the driver and that also didn't helped me out.
Here's the complete log:
DriverUpdateUI.exe Information: 0 : Log File Created 2/14/2015 8:34:52 PM
DriverUpdateUI.exe Information: 0 : Driver Manager: 14-2-2015 Running an Autodetect on Microsoft Windows* 8.1 Pro, 64-bit with build 2.0.0.29
DriverUpdateUI.exe Information: 0 : Intel Board is False
DriverUpdateUI.exe Information: 0 : Calling IDUUDetection.IDUUDetection().getDriverData with 100 driverInfos
DriverUpdateUI.exe Information: 0 : IDUU-Detection: HW signature count = 100
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0102
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0106
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0112
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0116
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0122
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0126
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_010A
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0F31
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0152
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0156
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0162
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0166
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0402
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0406
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_016A
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0A06
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0A0E
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0A16
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0412
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0416
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_041A
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_041E
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0A1E
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0A26
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0A2E
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0D12
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0D16
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0D22
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0D26
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_161E
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0040
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0041
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0043
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0044
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0045
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0047
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0048
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0049
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_004B
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0050
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0051
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Sign...
rschS
hello the new chipset is overwriting you can see new in registry
rschS
hello now need for trouble i have same in registry is already new chipset it is overwritten the update tool dont show this you have new chipset okay
Kevin_M_Intel
May I know what is the brand and model of your computer?
Kevin M
MB9
I build the computer and these are the specifications:
Motherboard - ASRock Z77 Extreme 4
Graphics card - AMD Radeon HD7950
RAM - 6 GB
I hope you know enough of the specifications I have.
- Maarten B
Kevin_M_Intel
Guys,
Our Chipset driver is a generic one for OEM systems. This means that installing our generic driver may not work on your systems and that is why you should install the chipset driver provided by the Computer Manufacture.
If you want to install our driver, you can try this one:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=20775&lang=eng&ProdId=816 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=20775&lang=eng&ProdId=816
Kevin M
MB9
RAM - 6 GB
- Maarten B
rschS
i have same problem when update chipset in drivermanager all stays old but in registry the new chipset is recognized version 10.4 the newst
rschS
hello i accept this because microsoft chipset version stays in driver manager old but the chipset is in registry recognized as new version 10.... all is okay for me
